Step 5That thong tha thong thong thong...
Luckily for us though the hole's in the center, easy to measure, hard to mess up. Mark your hole as measured in the geta calculator, then drill it out with a large enough bit for two pieces of the rope to go through. I used a 5/16 bit and wallowed the hole a little to make it an oblong.
For the back holes you want them to be just behind the front of the back tooth coming down at an angle that leads to the gap between the teeth on the bottom of the sole. Be careful that you don't drill into the back tooth as the bit comes through the bottom as I did on one of mine.
To thread the thongs slide one end of the rope through each of the back thong holes up through the top, then together through the middle hole. Tie a knot on the underside of the middle hole to hold the thong in place and cut off any excess, sealing the ends with a lighter to prevent fraying. Test the fit similarly to make sure they're not too tight or too lose before your tie the knot.
The thongs are 33" each on mine, this should be a good starting size for others as well, but I'd say start with something more like 38 each to give yourself room to trim them down. It's easier to cut away excess than to add more on later. If you like you can add cotton piping over your nylon rope now to give it added softness and color. measure and adjust your rope to size, then cut a piece of piping an inch or so longer so you can sew the ends of it up after you slide the rope into it.
Add Comment
