3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make Your Own Illuminated Signs
  • last photo ←
Want to express yourself creatively with light?  Make a mood light, perhaps?  Could you use a night light?  Make name signs or multi-word messages?  Using readily available materials, Illuminated signs are easy to make.  Any of these and more uses can be accomplished  with the simple methods in this instructable.
Step 1Gather Materials and Tools
To make a light, I used common corrugated cardboard, a piece of yellow paper, a small piece of acrylic sheet plastic, tape, glue, etc.  For tools, the usual paper cutting implements, i.e., straight edge, box cutter, scissors and so on.  I use a table saw to cut the acrylic, but it can be cut by scoring lines deeply on your cut line, and then snapping the plastic. Special tools are made for this, but a utility knife will work....USE CAUTION IF SCORING PLASTIC THIS WAY! The light source for these signs are mini christmas lights, available everywhere. They are low amperage, low watt, low heat lights and come in different sized strings, and colors.
39 comments
May 14, 2012. 7:21 PMoilitright says:
If you can believe it there is someone selling this technique on Craigslist for $175.00
Mar 17, 2011. 12:40 AMilldoyourdrugs says:
Stumbling across your ible i can't believe i forgot to post the pictures of my project inspired by you. I had a few more updated pictures but couldn't find them. I went to Michaels and used this multi colored plastic backing instead. I forget the name. I used black spray paint for the black areas. i hand cut out the font with an x-acto knife. I used a brown paper bag as a border for look and character. This was a huge hit. Thanks again.
Jan 1, 2010. 2:39 AMrlawrence says:
 hello, how did you make your letters so smooth, i had trouble making them that smooth
Nov 17, 2009. 8:46 PMilldoyourdrugs says:
Any alternatives to the acrylic such as something that can be cut by a scissor?
Nov 27, 2009. 1:18 PMHammerhead46 says:
You can get the acrylic in thin sheets that might be cut by scissors.
OR you can buy "PAGE PROTECTORS" (remember those plastic covers with a Black sheet of paper from school days?)  in up to 8.5" X 11 " in most department stores, (Larger at Office Supply Stores) and they can be cut by scissors easily.
Have fun.
Dec 8, 2009. 3:14 PMilldoyourdrugs says:
Thanks. Ill check out office depot or a similar place. I also thought to use the clear " projector paper".
Dec 5, 2009. 9:34 AMcorycar says:
Could you show a picture of your table saw?  Surely not a WOOD saw - it seems that the acrylic would shatter????
Dec 5, 2009. 7:06 PMcorycar says:
REALLY?  I'm surprised about that... especially with 1/8 inch... but cool.  I don't have a table top - but I do have a rotary saw (rip saw)  What kind of blade do you use - if I may ask?  I'm seriously intrigued by this...
Nov 9, 2009. 7:44 AMkathyh239 says:
Hey Creativeman,
You've hit another home run here.  I knew I shouldn't have retracted my previous marriage proposal to you!
Do you have any suggestions for what I can do with old blueprint paper tubes?   I get them from work - giant paper towel-type tubes 3 inches in diameter and 3-4 feet long.  Any ideas are appreciated.
Keep up the good work.
Nov 27, 2009. 2:13 PMHammerhead46 says:
I could use a couple of them also at a reasonable price as they could be their own shipping tubes if they are thick enough, and they could be sent at parcel post rates.
Nov 27, 2009. 2:10 PMHammerhead46 says:
Make Xtal Radios! http://www.midnightscience.com/ or http://www.vintageradio.me.uk/crystal/boys_book_xtal.htm or donate them to Boy or Girl Scouts along with plans for Crystal radio sets to start the next generation in electronics or crafts.
Nov 13, 2009. 10:51 AMmorrisonarts says:
The lIghted boxes are MARVELOUS --  I'm excited to try one.
Now, I'm looking at the pics of what you called " styrofoam mosaics".
What part is styrofoam?  The tiles?  If so, what did you grout them with.  Looked for a link to another Instructable . . .  Looking for GOOD kid projects and this is a dandy.
Nov 14, 2009. 9:06 PMdkfa says:
Ah..a Very nice way to save money then using neon lights in a a store. But, will this be more power efficient as a neon store light? Would It be as noticeable? Nice ible. 5*
Nov 27, 2009. 1:25 PMHammerhead46 says:
Neon Transformer about 120 Watts
Standard Christmas lights about 15 - 25 Watts.
LED Christmas lights about 5 Watts.
You do the math.
Attention grabbing, add a flasher bulb to regular Christmas lights or an electronic on off timer to LED Christmas lights and they will draw attention.
OR better yet add a sound controlled on off  for variable timing to local sound or music.
Nov 16, 2009. 12:50 PMwenpherd says:
Very very nice!
Nov 15, 2009. 8:21 PMilldoyourdrugs says:
DUDE this rocks. Its simple and effective. I love how you went with the Christmas lights as they are cheap and abundant. Nice work man. YOu are creative man. : )
Nov 12, 2009. 7:51 AMWingDings says:
This looks like fun! :)
Would it be better to use LED lights rather than incandescent ones, by the way, to stop the heat build-up?
I know you say that they are "low heat lights", but I would have thought these incandescent lights can still give out enough heat to significantly warm a sealed enclosure, causing early failure or damage? Or maybe that can be solved with some ventilation holes?
Nov 14, 2009. 3:05 AMWingDings says:
Yes, some of the LED lights are a bit more pricey, but they seem to be coming down in price all of the time. Maybe some day they will be as cheap as the incandescent type. The light they give out may be an issue, as you mention. I'm not sure if they generally give out as much light as standard incandescent bulbs - I suppose that varies with the kind you buy.
Another issue with LEDs is that the plastic packages around the light emitting parts often focus the light into a thinner beam than normal bulbs, which throw out light in all directions (unless they have the "cloudy" type of package). It might be necessary to site them a bit further back from the sign or use a piece of "frosted" plastic sheet or similar to diffuse the light, to avoid bright spots of light from being thrown onto the back of the sign, unless that kind of look is what people are after!
LEDs should have the advantage of being more energy efficient for the same light output, though, assuming the transformer that they're supplied with is an efficient one, of course.
Nov 13, 2009. 11:55 AMpiper1234 says:
mm so easy n' cheap it gives a "highlight" look to any inner space ; )
Nov 12, 2009. 5:14 AMbwvalentine says:
I'm going to make one of these for my studio window that I haven't been able to do anything with.  Awesome instructable! :)
Nov 12, 2009. 11:24 AMbwvalentine says:
oooh!    i love it :)
absolutely :)
Nov 9, 2009. 11:40 AMcowscankill says:
Another cool project! potential for a lighted globe idea? (poke holes in the globe where there are large cities and put lights inside)
Nov 10, 2009. 7:39 AMGoodhart says:
Or maybe at the Capital cities ?
Nov 10, 2009. 3:36 PMcowscankill says:
I was thinking of using needle sized holes for all of the major lighted areas... like if you were looking at a satellite image during the night time.
Nov 10, 2009. 4:30 PMGoodhart says:
Sure,  and maybe tiny start shapes or diamond shapes ♦ for Capitals, and make it a "teachable moment"  ;-)
Nov 11, 2009. 6:42 AMcowscankill says:
Haha, I was just thinking it would be a cool nightlight :)
Nov 11, 2009. 9:50 AMGoodhart says:
That it would be :-)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
638
Author:Creativeman
Retired, doing art work now. Great. Have the time and the money to spend doing what I want to do.
