Introduction: Make Your Own Kite in Less Than 20 Minutes!
Do you want to buy a kite but don't have the time nor money? This is a fun, easy and cheap way to create your own kite in less than 20 minutes!
Step 1: What You Will Need
Supplies:
-Sticks (3-4) that are 37-40 inches long
-Scissors
-Newspaper
-Yarn
-Cloth (can be an old t-shirt)
-Tape
-Tape measure
Note: the sticks and yarn can be found at Michaels
Hazard: scissors and sticks are sharp. Not meant for children
Step 2: Cut the Newspaper
What you will need:
-Newspaper
-Scissors
Make a square:
-Place the newspaper flat on the table (horizontally) and bring the top right corner to the opposite side (bottom left) making a right triangle
-Press on the edge of folded area to form a crease
-Use the edge as a guide to cut off the non-folded part (rectangle piece to the left of triangle)
Step 3: Cut the First Stick
For your first stick:
-Place the stick along the crease of the paper (diagonally)
-Cut off the part of the stick hanging off the edge of the paper
Note: You should not have any left over stick hanging off the paper
Step 4: Cut the Second Stick
Cut and place the second stick:
-Cut the second stick in the middle to create two equal shorter sticks
-Place one of the short sticks across the longer stick forming a cross
Note: the edges of the short stick should also be touching the edges of the paper
Step 5: Securing the Sticks Together
Tie a knot around the sticks:
(1)Loop on side of the short stick with the yarn
cross over the middle
(2)Loop around again
repeat 3 times
(3)tie a knot with the yarn
Note: make sure to keep the sticks in a cross like figure and that the string is pulled tight enough around the sticks so the cross is maintained
Step 6: Create the Frame of the Kite
Create a diamond :
-Cut third stick to fit space between each point of the cross
-repeat until all sides are fitted, creating a diamond shape
Step 7: Tape the Diamond to the Paper
Tape the diamond:
-Place the cross back on the paper where the longest stick is still aligned with the crease
-Tape each point of the cross
-Then place the sticks you just cut into the diamond shape
-Then tape all 4 corners while maintaining the diamond shape
Step 8: Tape the Rest of the Kite
Fit the paper around the frame:
-Carefully fold the edges of the paper over the sticks and tape it down
-Do this for all four sides of the diamond
Note: Make sure to pull paper tightly so the kite is sturdy and secure
Step 9: Make the Tail
To make the tail:
-Cut a strip about an inch to two inches wide of cloth
Note: length can be as long as you want it to be, usually about 13-16 inches
Step 10: Place the Tail on Your Kite
Connect the tail:
-place one side of the tail at the bottom point of your diamond about an inch up from the point
-tape the cloth to the kite
Note: bottom point is the most narrow corner of the kite
Step 11: Connect the Rope
To fly your kite:
-use your yarn to tie a knot in the center of the cross
Note: Do not cut the yarn from the spool because this is what you will use to fly your kite
