This will be a tutorial on making your very own Link costume from the Legend of Zelda game. This will assure your child gets cult nerd status on Halloween night as we learned when we went trick or treating. You will find out, the majority of the people have no clue what the costume is, but those that do will give your appreciative kudos.
This was all my son's idea, and it took about six weekends, and some late nights but the end product came out nice. The sword and shield were made out of wood (I thankfully had access to a laser cutter but it could be replicated with a jig saw) and I will provide cad files and pdf's of all the pieces as well as the laser settings for anyone who may have access to a laser cutter.
For the costume itself, I had a friend come by and show me how to do basic sewing, and now that I have made it, I will CAD a pattern and also upload several file formats for downloading. If you follow the link to flickr, you can see all the build images, and as I can update the tutorial I will: Link Costume
Thanks!
_jp
Step 1: Getting your materials and tools in order
Okay, so first things first, you are going to want to get your materials in order. I used basswood and some really thin plywood to build the sword and the shield. In hindsight, I think next time I would only use basswood. The plywood is a beast to cut, and bending is NOT fun.
Materials For The Build
1. Wood
Okay, so here is the supplier I recommend for procuring all your basswood needs: nationalbalsa. Eric and Tammy will set you up straight away. I have been using them for years and ALWAYS had prompt service. Tell them I send my love ;)
2. Glue:
I use
Aleene's Tacky Glue and 3M Super 77. I have these on hand for other projects, and you can probably get away with just one good glue that works well with wood.
3. Paint:
I used a enamel spray paint. Red, Yellow, Silver, Blue, and a clear coat spray.
Tools For The Build
1. Cutting Device:
If you dont have a laser cutter or a friend that has one, fear not. I suggest printing out the templates I will upload and using a jig-saw, band-saw, or similar tool. In the end, even if you use a laser cutter, you will see that I filed and sanded the material so it looked a little more battle weary, so a looser tool will not make the end product any less cool.
2. Clamps:
You really cannot have enough clamps. Seriously. If you dont have enough, use this as an excuse to go buy as many as you can. Clamps were vital in this process.
3. Magnets:
This one may seem puzzling, but it makes more sense once we get further down the road. Short of it is, that when you get to gluing pieces of the shield, you will find that some of them are hard to get a clamp on, so it is handy to have a couple of these around.
4. Sanding Files:
These will come in handy when filing the millions of pieces that you will assemble. This part of the process is probably the most tedious and annoying, but in the end, if you put some love into it, your pieces will have that battle-worn look that we know LInk has earned.
5. Orbital Sander:
I have one of these, so that is what I used. Honestly, you could use any sander. This one seemed to work well.
6. Sandpaper and Sanding Block:
I used 220 grit mainly for these. DONT buy a sanding block. Just use a scrap piece of wood, spray some Super 77 on the paper and presto: a sanding block.
7. Xacto Knife:
I used a large and small one.
8. Scrap For Jig
You will need to make a jig to bend the shield (if you want to), and I used whatever scrap I had. This end up being a lot of castoff pieces of chipboard and a couple dowels, but you could easily use some plywood and cut the shape out with a bandsaw.
Alright! We are ready to look at the design!
Step 2: The Design
So, after some hard internet searching, I actually pulled up on amazon a sword and shield that someone was selling. So I used these as a precedent, although if you look hard enough at the finished product you will see that I made some changes.
So I got the images, brought them into AutoCAD and scaled them to the size that I wanted. At this point I traced both the sword and the shield. You can get the two images below and do the same, OR since I did the hard part you can jump ahead to where we start cutting and assembling.
If you decide to do it yourself, you really need to visualize the end product and start breaking the shield and sword down in your mind into its component layers.
Next we will see what that looks like.
Step 3: Breaking Down the Components: The Shield
Okay, so if you chose to draw up the pieces, this is where you can check it against mine. I possibly made it harder than I needed to, but having built a ton of stuff like this, I really like to build up the process.
Okay so this is the shield. I made up a rough key to outline the main components. The colors are not indicative of the final product colors, but hopefully they will help show how the shield is broken down.
A: Triforce pieces - These were three triangular pieces cut out of 1/32" basswood (painted yellow)
B: Shield edges - These give the shield a little depth, and were cut out of 1/16" basswood (painted blue)
C: Head piece and buttons - These add more detail and were cut out of 1/16" basswood (painted silver)
D: Shield base pieces - This is the base of the shield. Everything glues on top of this. It is made up of three pieces laminated together cut out of 1/8" basswood (painted blue)
E: Bird pieces and basic sass - These parts make up the bird and the other general sass pieces on the shield cut out of 1/8" basswood (painted silver and red)
F: Red Buttons - These are the "jewels" on the shield cut out of 1/8" basswood (painted red)
G: Black Buttons - These are the three buttons at the edge of the shield cut out of 1/8" basswood (painted silver)
Update: I added a few PDF's since many don't have access to CAD. The files are "printed" on pages that are 24"x18"
1-40 of 66Next »
blahism says: Oct 1, 2012. 11:12 PM
I am having difficulty opening the file also.
jordan.pollard (author) in reply to blahismOct 2, 2012. 2:45 PM
Just uploaded some pdf's of the file. Its CAD based so if you cant open a .dwg file, then I am sure you had issues with it.
blahism in reply to jordan.pollardOct 10, 2012. 4:13 AM
Thank you Jordan for the follow up!
Dumchicken says: Mar 1, 2011. 6:20 PM
i cant open the file I:(
jordan.pollard (author) in reply to DumchickenOct 2, 2012. 2:45 PM
Just uploaded some pdf's. This may help.
jordan.pollard (author) in reply to DumchickenMar 3, 2011. 12:36 PM
What are you trying to open it in?
Dumchicken in reply to jordan.pollardMar 3, 2011. 3:20 PM
windows
dwoloshansky says: May 18, 2012. 9:13 PM
I would have to agree! My daughter loves Link and wants me to make her a costume etc. for Halloween but I can't download. Is there a chance I can get the files please! Thanks!
jordan.pollard (author) in reply to dwoloshanskyMay 21, 2012. 8:22 AM
Shoot me your email and I will get you the file.
bubbleheadz says: Apr 20, 2012. 8:20 PM
Would it be possible to send me a pdf of all the steps? This make-your-own Link shield is by far the best I've seen online!! :D
Uzutachi says: Oct 30, 2011. 5:49 PM
Something tells me that you actually wanted the shield edges to be painted silver, and not blue
GraftonGirl says: Oct 15, 2011. 6:01 AM
I can't download the DWG file either. And I can't download PDF's because i'm not a pro memeber. Could you possibly email me the pdf file? :)
jordan.pollard (author) in reply to GraftonGirlOct 17, 2011. 8:40 AM
Do you want me to email the dwg? What is your email?
mccombi says: Apr 17, 2011. 5:32 PM
I'm trying to print the components out to scale but can't get the dwg to scale correctly. Any tips you can provide (I'm using DWG TrueView) or is is possible to convert to a couple pdfs with items to scale?
jordan.pollard (author) in reply to mccombiApr 18, 2011. 6:40 AM
I am not sure how the viewer works. The rectangles around materials are 1' x 2'
If you cant get that to work, I will try to upload some PDF's
Let me know.
atomiclegocreations says: Apr 1, 2011. 6:58 AM
Coolest idea for this: Playing Zelda while wearing this! If you're playing crossbow training, it's almost like you're there. Just saying.
vernors says: Feb 3, 2011. 6:36 PM
omg. you put up a .dwg im so happy
cowscankill says: Nov 18, 2007. 6:21 AM
Link! He come to town, come to save, the princess Zelda!
sonofspikerr in reply to cowscankillOct 5, 2010. 2:08 PM
is that the one from system of a down?
cowscankill in reply to sonofspikerrOct 5, 2010. 5:19 PM
Yep.
sonofspikerr in reply to cowscankillOct 11, 2010. 4:13 PM
that song is amazing!
timjelly in reply to cowscankillOct 10, 2009. 11:09 AM
 zelda by the rabbit joint
hishealer in reply to cowscankillOct 8, 2009. 6:40 AM
I love that song!
cowscankill in reply to hishealerOct 8, 2009. 1:10 PM
I know, right? :D
darkmuskrat in reply to cowscankillJan 7, 2008. 7:42 PM
Lol, nice :D
zeldamax says: Feb 14, 2009. 6:21 AM
the costume looks more like ocarina of time than twilight princess
master-of-chaos in reply to zeldamaxMay 3, 2009. 8:59 PM
That's because Ocarina of Time was better.
sonofspikerr in reply to master-of-chaosOct 5, 2010. 2:07 PM
ocarina of time for 3Ds... Ive never played OoT, but im getting that right away
zeldamax in reply to master-of-chaosMay 25, 2009. 8:18 AM
i so agree, ocarina of time is way better than twilight princess
Duct Tape Dude in reply to zeldamaxDec 26, 2009. 3:50 PM
yup very poor story...i mean COME ON A WOLF SRSLY?!?!
oicarina of time had a great story...(and the halo custom edition map is pwnzor)
BarginsTech in reply to zeldamaxOct 2, 2009. 8:59 AM
AMEN nerdy friend! <3 Love the costume but i agree, kid link didnt have pants...
AlternateLives in reply to BarginsTechOct 21, 2010. 7:14 AM
Ocarina of Time was one of my favorite games. Majora's Mask wasn't bad, either.
JerBear says: Oct 2, 2010. 8:17 PM
the hat seems a bit... off. other than that, great!
humphreys7 says: Sep 26, 2010. 12:35 PM
Whenever I get emails from Instructables, I usually open the interesting ones in new tabs. Here's what I saw today.
265lutab in reply to humphreys7Oct 1, 2010. 12:50 PM
lol
pindalanderz says: May 11, 2008. 6:07 AM
wonder what people would do if i wore this to school........
Duct Tape Dude in reply to pindalanderzDec 27, 2009. 4:57 PM
I would get suspended. We are under a strict no-tunic policy XP
zeldamax in reply to pindalanderzMay 25, 2009. 8:24 AM
i wore something similar to this on halloween and i went into slackers for trick or treating, and they filled my hat thing with double bubble bubble gum
master-of-chaos in reply to pindalanderzMay 3, 2009. 8:59 PM
At my school, you would be my hero... of time.
theking in reply to pindalanderzSep 27, 2008. 8:20 PM
You Guys Know Young Link Never Wore Pants
1-40 of 66Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
