3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make Your Own Planner Pages
For several years I used a paper planner.  Each day had two pages.  One page was for the usual appointments and tasks to complete.  The other was for notes I wanted to make on any subject.  These could even be where I had put something for storage, or the details of a conversation.  The system I was using used an indexing procedure so I could find those notes later.
The reason I made my own pages was that I write with my left hand.  Most planner pages are designed for a right-handed person.  The binder rings really get in the way if you are left-handed.
Step 1Page for notes
Page for notes
The left side page in my binder used dots (the period key) to make a faint line on which I could write.  My pages were half of a sheet of 8.5 x 11 inch paper, or 5.5 x 8.5 inches.  Holding down the period key causes the page to fill with dots very quickly.  Because this page was on the left side of my binder, I left the right margin a bit larger than normal to make room for binder ring holes--about 0.70 inch.  I placed two planner pages on one sheet of paper formatted for Landscape rather than Portrait.
29 comments
Dec 27, 2009. 6:17 AMKEUrban says:
Phil,
Just a suggestion on your hole punch. I supervise duplication services at work. Take a big stack of sheets, sandwich them between two of your plywood forms with light cardboard (like on the back of a pad of paper) as the first and last pages of the stack, and then use a drill press to punch the holes. Except for the plywood forms (we have stops set up on the hole punch), that's how we punch hundreds of pages at a time.
Once the drill press is started, and before drilling, hold a block of wax against the bit to lubricate it. Then, drill away.
Jun 14, 2011. 5:33 PMpfred2 says:
You could probably make your own tubular bit out of a sharpened piece of metallic brake line tubing.
Dec 27, 2009. 6:11 AMrimar2000 says:
I'm also a lefty, Phil. Maybe I should copy your idea, because even though I carry my journal, I'm very disorganized with my designs: without exception, thay have lying around in loose sheets.
Jun 14, 2011. 5:30 PMpfred2 says:
You and me both. I have piles of papers lying around with notes, sketches, lists, etc. on them. Anymore when I get done with a project I toss out most of the associated paperwork that went into making it. I figure the project is its own documentation.
I have a thing for spiral 3x5 memo books, though I use some 3 ring binders as well, sometimes backwards, as I'm left handed too.
Left handers are the only ones in their right mind!
Dec 26, 2009. 7:58 PMAngryRedhead says:
I adore this level of commitment to organization and correcting flaws in common things that righties take for granted.  Kudos to you!
Mar 25, 2011. 8:19 AMmslaynie says:
You're very lucky. My father-in-law went to a small Catholic school, and the nuns actually tied his left hand down to force him to write with his right hand. I've also heard stories of liberal application of a ruler across his left knuckles also. He's got lovely penmanship now, but I don't know if it was worth it.
Jul 1, 2010. 6:04 PMJake_Rider says:
Cool, dude!!
Mar 3, 2010. 4:24 PMgreybunny says:
 I don't know what kind of planner you use, but doesn't this waste more time than it would cost? I am very picky about my planners (I use disposable as I don't have the space or money for a large one) and tried to make one before but after working on it for days I still couldn't get it to come out right - meanwhile wasting many pages every time i thought I had it right. And without a dual sided printer it takes so long. I understand this is instructables, about do-it-yourself, but sometimes you have to decide if something is worth your time and energy. How long did this take you?
Mar 3, 2010. 4:26 PMgreybunny says:
 A few months ago I got a planner I liked well enough for $3, that will last me till the end of fall semester (around Christmas). The only things I'd change about it would be having an extra page after the week (one week is 2 pages) for notes (I have to write in the margins now) and the font and cover.
Mar 1, 2010. 6:45 PMblodefood says:
I found a planner at a thrift shop that had a week on two pages but there were no day or month numbers so one could write them in.  It just happened that the pages were about the size of a half sheet of letter (north america) sized paper.  So I scanned them and printed out a bunch and slit them.  There were only three holes so I could use a regular paper punch and adjust the position accordingly.
Mar 1, 2010. 6:55 PMMehehehful says:
lucky duck. n_n
Dec 30, 2009. 9:20 PMmotorharp says:
This is a really cool calendar setup, thanks!  It's very helpful.
Dec 27, 2009. 8:16 AMehmbee says:
Nice instructable-while it may seem like an easy way out, I get my templates from DIY Planner. It lets you start with a pre-made, submitted template and go from there, without having to create an Excel document, etc. yourself. I need full-page planner pages for film projects (for shooting schedules, etc.), and they have plenty of those as well as Classic Size (5.5 x 8.5 in.) and Hipster PDA-sized (for 3 x 5 in notecards). Supplement these with your 'ible and the idea of dropping $20-$50 for planner pages seems absolutely ridiculous to the average DIYer.  Again, nice 'ible!
Dec 27, 2009. 3:09 AMlaxap says:
I have a "Time/system" planner. Due to the PDA an now the  gcal eras, I still use it but only occasionally, and mainly for sketches and quick notes.
I've been always highly annoyed by the holes arrangement and necessity to buy blank paper, or a specific punch, all sold at scandalous prices. This plywood + hole punch trick is a great idea!
How many sheets can you punch in the same time?
Dec 27, 2009. 3:17 AMlaxap says:
OK, 6 sheets, as told in step 7...
Dec 27, 2009. 6:43 AMAngryRedhead says:
I don't know if this would help, but I've discovered the wonderful leather tooling section where you can buy punches that you use with a hammer.  They're about $5/set and work GREAT on paper and lots of other materials, not so good on felt but meh.  It might be easier to swing a hammer than grasp a grip-style hole puncher.  Here's a step in one of my instructables where I use it on cardboard.  A bonus of the sets is that you can add holes to leather shoe/sandal straps.
Dec 27, 2009. 7:33 AMAngryRedhead says:
The punches get quite large if that helps.  I think mine go up to a 1/2" diameter which would be big enough for a ring binder.  Just saying in case it helps because I really like the punches and think they're a little bit of awesome.
For the record, I love your use of a jig for punching holes.  Very clever.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
476
Author:Phil B
I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying posting things I have learned and done since I got my...
more »
