Step 6Forming the Brush Holder
First: Hold the wire and put a "more than 90 degree" bend into it. This starts the edge of the curve you're going to create.
Second: Hold the wire against your form (in this case, a D battery) and curve the wire around it. You can also use the same method as in the base forming, using an open cylinder and holder the wire against it with your pliers. You don't want the bend to be an open U, make it a little more closed.
Third: Hold the pliers at the end of the U-type bend, and bend it back on itself. You can then clip the excess off and press that curl in on itself to create the little accent you'll see on the final product.
Note: You may need to bend the horizontal U shape down a little bit, to make sure your brush does not fall out of the U. This can be done easily with your hands.
Add Comment
