3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make Your Own Razor and Shaving Brush Stand
Step 7Finishing Up
Finishing Up
There you have it! You have now finished the stand. The little curl accent isn't just for looks, it will help you paint your stand (should you choose to do so). The original stand I made was finished with flat black enamel and a glossy clear acrylic.
If you do choose to pain the stand, the curl will allow you to hang it on a piece of wire for easy painting and drying. Remember, should you choose to paint with spray-paint, to use adequate ventilation. I do not recommend polishing, as a coat hanger is made out of cheap metal. Enamel or acrylic paint would work fine, and no harm should come to your shaving tools when resting in the stand. Someone suggested plasti-dip to me, but I think that's a bit excessive.
As you can see below the stand will hold either item, razor or brush, by itself. Centering the upright over the base, and extending the razor while keeping the brush closer to the center will help to distribute the weight correctly. If your stand will not stand up with just one of the two items, you may have made your base too small, upright too tall, or extended the brush holder too far. In this example the brush is not that close to the center, but my brush is very light.
The last picture is an example of what the rack will look like when painted. It is the prototype that I made, so the razor holder looks a little different. The method of bending the razor holder was improved for the second (for this Instructable).
6 comments
Jun 27, 2010. 4:27 PMtimburns says:
I tightened up the razor loop into more like a rectangle to store my straight razor. The design is perfectly simplistic and looks great. I like it more than a professional one because I know what went into constructed it, a feeling of accomplishment. Thanks TricksyHobbit!
Jul 17, 2011. 12:04 PMhyzerflip says:
I did basically this I think.
I also made my brush holder adjustable (as the two brushes I have are shaped nothing alike!)
I like that it can hold EVERYTHING I use (different razors, different brushes) and it cost me...nothing really. I had everything on hand.
I was self sufficient for real after checking out these pics.
I also made the bottom a bit different (like a semi circle) and I made the middle post in 3 bends not 2. I made clearance for a soap mug under the brush!
Sep 4, 2009. 4:01 AMjoneill says:
I just began shaving again with a safety razor and shaving brush, after over 40 years. Taken me about a week to remember all the old tricks, but have really learned to enjoy it. I was going to have a friend with woodworking abilities make me a nice wooden stand, until I happened upon this great website. Took me about a 1/2 hour, plus twice that long to tweak it but it came out great. Really a nice simple project with great satisfaction. Now to finish it off with a nice paint job....
Aug 9, 2009. 9:42 PMsaini_madhur says:
neat looking project. loved it
Mar 29, 2009. 12:49 PMchlsmith says:
Good idea! I've been looking for one of these and they cost $20 at a minimum, for a basic stainless steel model! Mine may not be that nice looking, but it does the job.
Jan 21, 2008. 1:30 PMTigger46 says:
Cool Project! I was lamenting the cold and rain and was uninspired. But was missing being able to do something. I modified your design for myself, since I don't use a brush for shaving. I made a closer loop to support a tooth bush instead! Thanks for the inspiration. (Inspriration:def. Touched by God) Cheers!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:TricksyHobbit
