Remove these ads by
Signing UpStep 1Materials
As far as tools go you will need:
1.) Soldering Iron
2.) Solder- Make sure that you have rosin core solder, acid core does not work on electronics.
3.) Multimeter (Optional, but very handy)
Twenty dollars spent at your local Radioshack will get you all of the parts you need for the pedal:
1.) Resistors: 470ohms x 3 (Yellow-Violet-Brown)
4.7K x 1 (Yellow-Violet-Red)
2.) Potentiometers: 100K x 1 (the small type that solders onto the board)
1M x1 (the big type that you attach the knob to)
3.) Integrated Circuits: LM386 Audio Amplifier
555 Timer
4.) Transistors: PNP Transistor x 1
5.) Capacitors: 10uf Polarized x 2
.1uf Ceramic x 1
220uf Polarized x 1
6.) LEDs: Green LED x1
Red LED x2
7.) Connectors: Female Guitar Jack x 2
9v Battery Clip x 1
8.) PCB: Any standard perfboard should do, I used one about the size of a credit card that I bought at Radioshack.
Thanks person
Does the LM386 N-1 not have a fixed internal gain, or are we talking about the input voltage that matters? Or referring to putting a variable resistor between pins 1 and 8?
spel30 brought up the type of speaker used, and he has a good point. I don't know very much about wattage or speakers, but I know that it at least takes more wattage to drive larger speakers.
Input voltage does matter, but AFAIK, the LM386 amplifies the signal regardless of how high or low it is. I could be wrong on that one.
am i missing something?
RC values:
Resistor: 1k
Capacitor: 10uF
:D that should also add a less harsh tremolo
http://www.youtube.com/watch?v=t1gQo_ikZ6M
What kinds of frequency range will this operate at with your default resistor values?
