3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make Your Own Vacuum Sealer Bags On The Cheap!
I  got a food sealer today so that I could store the processed meat from my SCRAPS project for long periods of time. [Actually I got two but I will explain that later.] I figured that I might as well use the sealer to save my leftovers too! Previously I just covered the leftovers with aluminum foil for a week and whatever's left on Sunday gets tossed. Using a food sealer will allow me to store leftovers for a month or more!
The only problem that I came across is the bags that are “specially made” for the food sealer cost a fortune! They aren't even made from recycled goods! I searched google to no avail on solving the problem, the closest I got was budget rolls $10 for a 8”x50' roll [33 square feet] and that is still outrageously high. I was perusing the plexiglass section when I saw painters plastic in 10'x50'x3.5mil rolls for $7 [500 square feet] so I picked up a roll [I splurged and got the recycled roll. The non recycled rolls are cheaper, but wheres the green in that?] .
I got home and made a bag using the sheeting and couldn't get it to vacuum. The problem was that the sheeting created its own seal too high up on the bag and wouldn't suck the air out of the lower part of the bag. A bit more googling and I found that the reason for this is that the “special” bags have air channels to allow the vacuum to suck all the air out.
I started trying to make my own vacuum bags by ironing the sheet over a window screen [didn't work] by using a tube to suck out the air and then sealing the corner [didn't work] and by attaching a straw to the bag and trying to seal it [didn't work] I was about to give up when I looked over at my hot glue gun and got the idea to make an air channel using hot glue.
The advantage of using hot glue is that it is non toxic, cheap [$3 for a 100 pack], and hot melt! I made a channel, made a bag, and tried it out. Shazam! It worked wonderfully! It worked so well that I decided to make an ible out of it!
Before I knew it I was vacuuming everything I could, marshmallows, bread, even a cassette tape [it was there, I had a bag, now I have a vacuumed cassette tape.]
Want to learn how? Of course you do, you read the whole intro didn't you?
Step 1Get Your Stuff Together!
You need:
A vacuum sealer [[[this is something you dont want to cheap out on, I got the el cheapo brand first because it was half the price of the others, got it home and found that it couldn't suck the air out any better than I could with a straw. I returned it and bought the $100 food saver one with the attachment port and never looked back.]]]
3.5 Mil or thicker plastic sheeting [The more recycled it is the better.]
Hot melt glue [a glue gun would help too]
Scissors
Food [unless you want to seal your cassette tape collection...ahem]
12 comments
May 2, 2012. 10:59 AMskeptic777 says:
Update on my last post. I found that the nylon screen strip worked really good. However even though it looked like it had a good seal, it has a tendency to leak very slowly. I cured this problem by installing the strip approx. 1 1/2 inches from the top opening. Your first seal will be across the screan while evacuating the air and then make a second seal on the clear portion just above the screen. It has been approx. four hours since I made a test bag and it is still holding it's seal.
Another method is to cut a one inch wide strip and run it from top to bottom of the bag, again leaving room at the top of the bag to make a second seal on the clear strip at the top. I found that this works just as well and I am using less screen in the project.
May 1, 2012. 2:35 PMskeptic777 says:
I tried the glue strip thing and a few other things and today I came up with something that actually works. I kept looking at and thinking about the commercial vacuum bags and how they are made. A year or so ago I purchase some vinyl screen for a home project. Today, I got the bright idea to cut a piece about half the length of my homemade sealer bag. I placed it inside the bag and proceeded to vacuum and seal just to see if it would work properly. Walla, it worked. Sucked all the air out and gave me a good tight seal. I will do it this way from now on. It really mimics the commercial bag.
Apr 10, 2012. 12:44 PMskeptic777 says:
First of all, I purchased a roll of 6 ml plastic sheeting. I followed the instructions to a "T" but kept having problems with my vac melting the bag. I finally came up with the idea of laying a piece of three ring binder paper between the plastic material and the vacuum sealer. Walla, it worked. Good seal with no leaks. I followed the instructions by using a glue gun and found it to be a hassle. Instead, I cut two thin strips of 6 ml plastic placed one on top of the other and laid them about a quarter inch a part down the inside center of the bag. It worked but again, I found using two stips a hassle. I decided to use a thin double strip of 6 ml plastic laying it about a quarter inch from one side of the bag. You can secure it with a small piece of scotch tape as long it is not located in the sealing area. It worked. The bag I sealed has been laying on my end table next to my recliner for three days and there has been absolutely no leakage.....
**** I tried using printer paper instead of three ring binder paper and found it to be to thick.
Feb 1, 2012. 7:28 PMthedestroyer says:
This is uuhhhh-maaaazingg (singing)...i got a foodsaver 2 Christmases ago and thus far have barely used it bc i'm being stingy with the way-to-expensive bags...excited to try this ible out!
question...at this point, have you had any seal failures after time? Have you tested any of the seals over a longer time period, say a month or more?
Sep 20, 2011. 4:40 AMsteved5600 says:
You need to make sure it's not PVC plastic. PVC out-gasses real bad and is toxic. It will also add a plastic flavor to the food. metallized polyester, polyethylene wrap are some of the best for bags. Mylar is also excellent. I steer clear of plastics from china that do not specifically state what kind of plastic is used. They have a terrible record when it comes to safety.
Good rule of thumb is if the plastic has a strong smell it's out-gassing and will flavor the food.
Nov 12, 2010. 3:32 PMPS118 says:
Great idea! Those vac sealers are a great idea, but the stupid bags are just unfeasibly expensive. I mean, who would pay $2.50 to seal half an avocado when you can just go buy a new one for 99 cents?
Some questions:
What is the reason for the lines of hot glue?
Also, are plastic sheeting/hot glue toxic? (Just wanted to ask cuz, you know, they're not really designed with food in mind.)
You have my 5 stars! :)
Nov 12, 2010. 4:07 PMPS118 says:
Sweet! I'm SO trying this!
Nov 10, 2010. 11:23 AMe1ioan says:
I have to make a note to never eat in your house.
Nov 12, 2010. 9:15 AMe1ioan says:
Because of the cat in the refrigerator touching the food ;-) Thanks for the instructions on how to make Vacuum Sealer Bags, very helpful.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:MisterInnovation(Check out my blog! [please?])
I am a 21 year old college student who doesn't think like other people do. Most people see trash I see an eco-friendly project waiting to be built! I am not to be confused with a hippie, my parents ...
more »
