Make Your Own Waterproof Matches!
9,247
170
14
Published
Introduction: Make Your Own Waterproof Matches!
About: I am a maker. As founder of MakerBlog, I enjoy sharing my creations with others.
Making waterproof matches at home isn't anything new. In fact, this instructable was inspired by "How To Make Waterproof Matches." But I wanted to make something original. I wanted to remake waterproof matches out of something unique. So, instead of using traditional candle wax to waterproof my matches, I used the classic kid's toy. Crayons!
Step 1: You'll Need
  • A Lighter
  • A Disposable Plate
  • A Crayon
  • Several Matches
  • A Knife or Razor
Step 2: Preparing Your Matches
Using your knife, cut the paper wrapping off of your crayon. It doesn't matter what color the crayon is, but I used white crayons. Lay your matches out on the disposable plate, preferably putting the heads close together.
Step 3: Waterproofing Your Matches
Fire up your lighter, and hold the tip of the crayon next to the flame. Rotate the crayon constantly, so as not to burn it. Let the melted crayon drip onto the match heads. It should cover all of the head, and about a 1/4" of the stick. Once a small puddle of crayon wax has gathered around the head of the match, pick up the match and roll it in the melted crayon. This is to ensure that the entire tip is covered in crayon wax. Remove the match from the puddle of wax, before it dries.
Step 4: Congratulations!
You have just made your own, completely unconventional, waterproof crayon matches! The picture above shows the matches floating in a bowl of water. I let them soak for about 5 minutes, and then tried them. They still worked! One of the upsides of using crayons instead of traditional candle wax, is that you don't have to remove the crayon wax before striking. You just need to dry them off and strike them. I'm not sure why this works, but it does! I know, because I did it!
I hope you enjoyed this instructable, and I hope you'll make some of your own "crayon matches". I also encourage you to comment and tell how well yours worked, and make suggestions for possible improvements. Thanks!
Wax Challenge
Runner Up in the
Wax Challenge
    • Stick It! Contest
      Stick It! Contest
    • Water Contest
      Water Contest
    • Creative Misuse Contest
    14 Discussions
    The first three people to leave a comment--with a link to a Facebook page on which they shared this Instructable--will receive a free 3-month pro membership!
    Thank you to those who shared my Instructable! The three free pro memberships have been taken, but you can still feel free to share it! Thanks!
    Thanks! Can't wait to try it.
    cool beans man I use this alot!!
    Awesome ideal for scouts to keep in their patrol boxes.. https://www.facebook.com/karen.medlin.79/posts/10204912737999087
    As best I understand it, the primary difference is the amount of pigment in the wax. Interestingly, that combination of wax and pigment makes the perfect match waterproofer, because you can strike the match without scraping crayon wax off of the tip. In most candlewax waterproofing projects, you have to scrape the wax off of the tip of the match before you attempt to strike it. Also, broken crayons are generally easy to find, whereas candles generally cost more than $1. As you can see, there are a couple benefits to using crayons over candles. I hope I've been helpful!
    Great Idea, who doesn't have Crayons??? I have children so I have lots of crayons at home. Making Water proof matches is something that everyone should do and keep on hand with or in an emergency kit with candles. Great spin! Nicely done. :)
