Make Your Refrigerator Spot Less Using Lemon and Vinegar Tips and Tricks
661
5
4
Posted in HomeCleaning
Introduction: Make Your Refrigerator Spot Less Using Lemon and Vinegar Tips and Tricks
About: DIY and Knowledge Builder
If you are like me and you use your Refrigerator for most of the time then your Refrigerator will consist of many spots which is an heart break to you. So for removing that today I'm gonna show you a mixture which removes of the spot in your Refrigerator and makes it look so good.
And this is my entry to the contest so if you like my instructable the don't forget to vote which meanse a lot for me.
So let's get started with what made me do this.
Spotless Contest
This is an entry in the
Spotless Contest
Step 1: Fridge Has Many Problems...
In my case I made this Instructable when my mom said me to clean the refrigerator.
As it was used very frequently in our house and my younger brother shows his artistic nature on it.
After some research I came up with a mixture which I think effectively clean the stains so let's get started.
Step 2: Apparatus Required
You will need:
1. Lemon ( get it from local vegetable market)
2. Vinegar ( local general store)
3. Salt ( common salt )
4. A cloth ( a clean old cloth)
5. Knife and cutting board.
Of course an untidy refrigerator.
Let's get started.
Step 3: Take a Lemon and Cut It to the Half
Now take a fresh lemon and then using a knife cut it into two halves.
Here in the image I didn't use a cutting board but it is recommended.
As the liquid from lemon can leave spots on your kitchen support.
Step 4: Get Juice Out of Lemon
Gently crush the lemon to get juice out of it.
Step 5: Add Vinegar
Add 2 cups of vinegar to the mixture. Refer the image above.
Followthe steps in a correct order.
Step 6: I Found Something Wrong
In my first attempt I misordered the steps then I found that something wrong was going on in the bowl.
The reaction made me worry and get tensed.
So to avoid that follow the steps carefully.
Step 7: Adding Salt....
Add one teaspoon of salt to the mixture.
This makes the nature of mixture from highly acidic to little neutral nature.
Step 8: Dilution....
Dilute the solution using some water. I mean clean water.
Step 9: Dip the Cloth
Carefully dip the cloth into the mixture.
I recommend to have gloves to your hand.
Step 10: Cleaning Time...
Now clean all the spotty places in your refrigerator.
Also between the grills.
And you may also have some food marks it will be gone use little pressure on the tough stains.
Step 11: Now Your Refrigerator Is Spot Less
Wow you had done that and let your mom be surprised on your work.
I hope you liked this one. If you have any queries please comment below I'll definitely respond for all your questions.
Thanks for spending your time on this.
And this will be my entry to the contest show your support to me by voting! Thanks in advance!
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    4 Comments
    This is a very known tip. You're wrong when you write that vinegar makes the mix more neutral, vinegar is almost as acid as lemon juice, probably more I think.
    Thank you!! I think you will try it
