3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make Your own SkullyBoom Wearable Speaker
Background
The SkullyBoom SB1 is the result of a collaboration with toy customization company Delicious Drips and vinyl toy manufacturer, Urban Warfair. Together they have merged to start a new venture called SkullyBoom.
How To
We're gonna tell you how you can make your own prototype right here and get bumpin'.
Materials
In order to make your own SkullyBoom, you're gonna need about $40 in materials, which is not bad. You will also need a soldering iron and a drill with various size bits. You will need a 1.75mm drill bit and a 2.2mm drill bit. You will also need something to cut through vinyl. A dremel with a rotary tool, a saw, or a razor will work. You will also want a grind wheel or a dremel to shape plastic.
Here's what you need:
1. DIY Skully
http://store.deliciousdrips.com/products/diy-skully
2. Philips Portable Speaker System
http://www.google.com/products/catalog?q=philips+portable+speaker&oe=utf-8&rls=org.mozilla:en-US:official&client=firefox-a&um=1&ie=UTF-8&cid=2738207538093981814&ei=HmQ2Sv7_IcPdlAeXu_SoCQ&sa=X&oi=product_catalog_result&ct=result&resnum=1#ps-sellers
3. You need 3/8" Thick acrylic that's about 4"x4", and a 1/2" thick piece of plastic that's around 1/2"x2" (check Tap Plastics)
4. 2mm threaded screws that are about 6mm long (any hardware store)
Order your own Customized SkullyBoom
IF you're too lazy to make your own, then check out the link below to see how you can get your own SkullyBoom.  The new site we've built allows you to customize your own, so HAVE FUN WITH IT!!!
http://www.skullyboom.com
Step 1Off with His Head
Off with His Head
1. We want Skully to be a little slimmer so we're gonna cut him in half from the side. There are two little nubs that are Skully's cheekbones. You wanna cut him just behind those cheekbones to allow enough room for the speaker. I used a ban saw to do this, but if you don't have access to one, you can use a heat gun and a razor. Just make sure to draw your incision line first.
2. Next, you want to cut out his big eye. Using the heat gun and a razor will work fine for this part. It doesn't even have to be neat, but you just wanna be able to leave a little bit of lip around the edge (approximately 1/4" should be fine). You'll use the lip to epoxy the speaker in later.
3. While we're here, pull out those Philips speakers and take those suckers apart. There are three screws on each speaker housing. Once they're open, you remove another three screws and then pry the speaker out of the housing. Test that they fit in the eye. You will notice that there is a little notch on the speaker. Drill the corner of the eye socket to fit this notch.
11 comments
Aug 31, 2009. 1:55 PMKohdai says:
u have any idea how much @ target?? amp's gonna come with it if you buy it @ target right?
Aug 30, 2009. 2:15 PMKohdai says:
where did u get the speakers?
Jul 23, 2009. 1:07 AMCathoHolic says:
i just noticed in the second video.... actually noticed in the beginning but not cared. That's an X-mini speaker isn't it? How do you make a amp board to be build in?
Jul 23, 2009. 12:09 AMCathoHolic says:
nice idea, best of luck
Jun 18, 2009. 12:09 PMHoudinipeter says:
How hard would it be to add an output to this? so it'd be kinda like a smokey mini amp (http://guitars.musiciansfriend.com/product/Smokey-Mini-Amp?sku=483005&src=SHPSIMMF&ZYXSEM=0). then you could also use it for playing bass on the move.
Jun 16, 2009. 5:44 PMbowmaster says:
Now I can have my own theme song!!!! I think I will use "Sexy back".
Jun 16, 2009. 4:04 PM=SMART= says:
Wow looks really cool ! Great idea too ! I wish you and the company the best of luck !!
Jun 15, 2009. 9:08 PMdeedeedee9 says:
this reminds of something like skullcandy would do
Jun 16, 2009. 7:05 AMstephenniall says:
hmm very cool
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:DeliciousDrips
