loading
This is easy, like making a real 3D cube out of anything.
I did it for the first time using popsicle sticks.
It was hard so I don't recommend using popsicle sticks,
maybe skewers and super balls.
I call this a real tesseract because although it's stuck in 3D space,
it has all it's edges of equal length, just like a real cube or a real square.
Often tesseracts are illustrated as a small cube inside a big one.
Not this one! And No, this is not an "impossible object" illusion!
Why did I Make this?
1.A sculpture and to see how hard it was.
2.Imagining the possibilities of making (the frame of) a
"flux conductor" or a "flux inductor" ...
maybe even a "flux capacitor".
3.Wondering what would happen if I made the items in "why #2".
4.It's about time I Make something new on here!
A flux conductor or inductor would perhaps be a wire that follows a
"hamiltonian circuit path" around the hypercube.
That means a wire that goes to each corner only once,
of a square object of any amount of dimensions.
Tesla had not much more than wire to use as electronic parts.
Who knows what an electric tesseract might do?
This model was inspired by the 2D drawing of a hypercube (tesseract).
A Cube is an object with 6 sides which are squares.
A Hypercube is an object with 8 sides which are cubes.
Step 1: Make a cube
This should be easy, just make two squares and then add equally long
lines between them.
It's not so easy with ice cream sticks. I cut angles on the ends so they
were shaped like parallelograms (with a miter) hoping they would line
up perfectly at the corners. I did not do any math to see if 45 degrees
is the correct angle, and still now have not.
In "junkyard mode", I propped it up with cans barely successfully while
I glued it.
Step 2: Make another Cube... wait!!!
The second cube is going to be harder.
It must be linked to the other cube like a chain,
so that one corner of it is inside the other cube.
It was really hard to make this second cube with
ice cream sticks and glue, because it needed to be
shimmed up, supported above the bottom of the other cube,
in a way so that it wouldn't fall apart.
Yes, I'm using the same picture again.
Step 3: Connect the corners of the cubes
Lift up the second cube into a position where
you can connect the corners together with
8 more sticks. There are actually a lot of
possible positions where you can connect the
second cube. These correspond to rotating
the hypercube somewhat , in a way.
But find one place you can support the upper cube and
all the corners are one stick-length from the corners on the
other cube. Then add those sticks.
Just like you connect the same corners of two squares,
connect the same corners of two cubes to make the hypercube.
Step 4: Done. Now think of weird 4 dimensional experiments.
Picture is not ready now. The glue is still drying.
Ideas I haven't tried yet:
1.Wire a hamiltonian circuit around the hypercube and run small currents
through it. Put a gimbaled or regular compass in the middle and see if
anything weird happens.
2.Wire the hamiltonian circuit and then hit it with a "quarter shrinker"
and see if you get a black hole or something. I don't know yet.
3.Make the hypercube out of metal and see if it rings like a triangle,
or has any other musical properties.
4.Wire up the hypercube with lines of EL-wire (neon wire) and use a
microcontroller to illuminate the 8 cubes in sequence. Actually LED's
would be easier to use. If done well, any hyperdimensional magic
(magnetic) should be detectable, but the lit-up-cubes will look like
cubes and you will be able to prove at science fair that hypercube
sides are 8 regular cubes. To do this you may have to stare at the
completed tesseract until your imagination shows you clearly where
all 8 of the regular cubes in the hypercube are , and when "illuminated"
everyone else will see them too.
5. hmmm... ? I'll see you again yesterday!
Pictures: (All of the Same Object)
First: One of the "emergent" (not made) cubes illuminated with EL wire.
Second: View with EL wire off.
Third:Typical "tesseract" looking view , a small cube appears inside.
Step 5: What's a Flux Reactor?
I don't really know, but ask a radio engineering guru,
especially one who is familiar with fractal antennas,
what he might expect of a "reactive" component
consisting of the tesseract made entirely of THESE:
(Picture of a primarily inductive, secondarily capacitive
reactance element made of part of my tesseract.)
Reactance is ... an imaginary resistance characteristic of
inductors and capacitors which actually affects alternating currents.
This could be just another "scalar wave generator",
which in my experience is useless, but ya never know.
It is a typical "resonating tank" or "loopstick antenna",
with a specific resonant frequency or band.
IF weird people do weird things, THEN weird things happen! - Logical?
An ordinary mouse is the preferred controller for selecting which,
if only one, of these reactive elements is driven at a time, because
it is encoded in gray code, which counts in the order of a
hamiltonian circuit, which again is the path to all the vertexes of
a hypercube of any (in this case 4) dimensions. Think outside the 4D box!
<p>the small cube in a cube is used for some 2-d renderings.turn your model around a bit and if you find the correct angle to look at it thats what you will see.</p>
<p>I just had a crazy thought. If shining a light on a 3-d object causes a 2-d shadow, would that mean that the shadow of a tesseract would be 3-d?</p>
No, you'd be projecting it onto a 2-d surface no matter what.
<p>no it wont be anything because we live in a 3 d world. there is no real 4th dimension(as you are reffering to it)</p>
I recommend using K-NEX pieces, since they work really well.
lbenedetti is correct. The reason the x y and z sides of a tesseract have uneven sides is because the tesseract we are familiar with is just a 3D shadow of the real thing. If you take a wirefram cube and shine a light on it the shadow is a square with a smaller square inside of it. Pop it up a dimension, and boom, you've got a tesseract.
The only problem that I have not read on here yet is the fact that his representation of the tesseract has equal sides. As Carl Sagan states when an object moves down a dimension it loses it's regular properties meaning that it is no longer made up of right angles and equal lines. Sagan shows this perfectly by taking a <br>3-D glass cube and showing it's reflection on a flat (2-D) surface. If you were to take the tesseract from the 4th dimension to the 3rd it would no longer have the 90 degree angles or the equidistant sides.<br><br>
http://www.google.com/imgres?imgurl=http://www.daviddarling.info/images/tesseract.jpg&amp;imgrefurl=http://www.daviddarling.info/encyclopedia/T/tesseract.html&amp;usg=__sRSSsqg9gVUhaOvOxUVpRRa3094=&amp;h=575&amp;w=780&amp;sz=21&amp;hl=en&amp;start=0&amp;sig2=nnRKgkMmVVcDVUhhz5xvVA&amp;zoom=1&amp;tbnid=rg8cN7q13FrV1M:&amp;tbnh=145&amp;tbnw=196&amp;ei=OVjSTejsD4-Bswa734GkCQ&amp;prev=/search%3Fq%3Dtesseract%26um%3D1%26hl%3Den%26safe%3Doff%26sa%3DN%26biw%3D1120%26bih%3D602%26tbm%3Disch&amp;um=1&amp;itbs=1&amp;iact=rc&amp;dur=397&amp;page=1&amp;ndsp=15&amp;ved=1t:429,r:0,s:0&amp;tx=55&amp;ty=57
A more appropriate title might be "a projected tesseract"; this is no more a tesseract than two squares joined by lines in the plane, of length equal to the sides of said squares, is a cube.
I agree mostly. But it's definitely 3-D and can be used as a model or frame for education and experiments. Since I haven't done them yet, I can't make any claims. It is reasonable to expect nothing unusual will happen.
It's definitely 3D, but you said it was real and 4D. <br/><br/>You can't create a non-3D object in a 3D universe. <br/><br/>(<em>perhaps</em> with the exception of a Nobius strip)<br/>
you can create a "2-d" object: a shadow is a 2 dimensional "object" in a 3-dimensional world.
Not really. Not enough coordinates means we won't be able to interact with it. Too many coordinates mean we just use the 3 standard coordinates.
With the fact that a 2 dimensional object casts a 1d shadow and a 3d object casts a 2d shadow, does that mean that a 4d object casts a 3d shadow?<br>If it did, I could see in the future all kinds of strange things being created as by-products of the fourth dimension, possibly even in a state of matter?
A shadow isn't an object. You see an object when light strikes it, bounces off and hits your eyes... basically. Where there is no light, since something is obstructed, it casts a shadow.
An "Object" is relative to the space in which it resides. In two-space, there is no light, since light is both a particle and a wave. Hence, a shadow can be considered an object. Also, if you don't like the shadow analogy, what about a projection?
Right, which is why my conjecture is that the number of dimensions an object has = the number of dimensions in the universe that possesses it. <br/><br/>What is two-space? You're losing me here.<br/><br/>The same applies for projection.<br/>
1-space = 1d 2-space = 2d 3 space = 3d etc. those terms are used in vector math, generally, when you expand theorems in the second dimension into the third, fourth, etc. <br/><br/>Since a shadow does not reflect light, it is most definitely not 3 dimensional. However, it IS an object. An example of an object that doesn't reflect light is glassware in a glass of oil. The Object DOES NOT reflect light; the light passes right through it. <br/><br/>Just because you can't see something doesn't mean that it isn't an object. IE Air, light doesn't bounce off of it much, but it's still an object.<br/>
You cant create a REAL 4-D or higher object in a 3-D world. I
you're right. However, the concept here is if we can express a 3D Object on a 2D surface, we can express a 4D object in a 3D Universe.
Just think about this: A hologram is a 3D or possibly 4D image on a flat plane. The 4th dimension is usually time on animated holograms, but imagine a ... hologram of ... a 4D mirror that reflects any light coming from a 4th space dimension toward you. What might you see? If there are no real 4D objects, a hologram of one must (and can) be synthesized or computer generated. If a flat hologram can hold a 3D image, a 3D hologram should be able to hold a 4D image. But that's in a short time ago and a galaxy not very far away. (bent star wars ref.) Also, fractals are real and have dimensions which are fractions. On second thought, most of them are full of "imaginary numbers"-sorry that's just a math joke. Snowflakes and rivulets and leaves are real fractals.
the 4th dimension is usually time? i don't know if it ever is :) is that hologram really flat though? and is the image really 3D?
Fine, 4 spatial dimensions! What this is, is taking a 2D drawing of a 3D object, and making it 3D. So now its a "drawing" of a 4D object in 3D.
Right. That's why it's a "projected" tesseract.
there are two other ways to represent a tesseract.<br/><br/>one is enclosed, which is basically a large cube with a smaller cube inside, with its corresponding vertexes joined together with lines (in this version, like the next, has 8 'rooms', one in the center, 6 represented by the warped cubes along the sides, the top and bottom, and the 8th one being the surrounding space around this figure, which is easier to understand in the second figure).<br/><br/>the other figure is inside-out (or unfolded), and looks like four cubes stacked on top of each other, with four more cubes connected along the sides of the second to the bottom cube on the stack (depending on how you unfold it). it looks like an upside down 3D crucifix (this figure also has 8 'rooms', but they're more ... corporeal ...in this shape.... the 'outside' room is now the room in the middle of the 4 protruding cubes, the 'center' cube from before is now the very top cube, the 'top' cube should now be at the bottom of the figure, and the 'bottom' cube should now be second from the top, right under the 'center' room. the 4 rooms around the sides of the enclosed figure should now be the ones protruding outward.)<br/><br/>this figure you've made does demonstrate all 8 rooms, but it's a bit more confusing visually.<br/><br/>the purpose of the 4th dimension of this shape is that it allows you to move from one 'room' to the other in a straight line and come back to where you started. it doesn't really have anything to do with time travel in the commonly used sense, but simply uses the 4th dimension as a way to fold across the 3rd to come back to where you started. unfortunately, since all walls are connected to the walls of the other cubes, once inside such a structure it would be impossible to exit. every exit in this 'crooked house' would lead to one of the other 7 rooms. an awesome short story by Robert A. Heinlein called &quot;And He Built a Crooked House &quot; explains how being inside this theoretical structure would work, though takes an artistic license with how they get out of it. you can read it here: <a rel="nofollow" href="http://www.scifi.com/scifiction/classics/classics_archive/heinlein/heinlein1.html">http://www.scifi.com/scifiction/classics/classics_archive/heinlein/heinlein1.html</a><br/><br/>hope that helps anyone who doesn't understand what they're making with Popsicle sticks. :P<br/>
Correct me if I am wrong, but your second visualization of the tesseract ("upside down 3D crucifix) is actually the net of a tesseract. It's like how if you unfold a cube you get a crucifix divided into 6 squares. When you "unfold" a tesseract you get the 4 stacked cubes with 4 cubes surrounding the second to last level.
exactly.
AAAHHHHH I"M FREAKING OUT ... so there is more then one god??
Corey we're not talking about god or gods. Off topic or typo error?
if there is an alternate dimension?
time is just the perception of change
Yup :)
um 4D is a measure of time (example if i leave an ice cube out in -0 tempature will it stay? yes! but if i leave it out in 100 degrease tempature? no! <br>
It is definitely 4D. The fourth dimension is time, and as it exists for any measurable time it has a 4th dimension. The shape doesn't make it 4D, only makes the 4th dimension a bit easier to imagine.
Actually if it did have the dimension of time it can be anywhere at any time. For example: it could appear and disappear, and then 4 appear in different places. Also, time as a dimension isn't accepted by every scientist.<br/> BUT, a tesseract has a different kind of dimension (another dimension of space, but it still has 4 dimensions). The 4th dimension of the tesseract is the &quot;W-axis&quot;... the directions are: left, right, up, down, forward, backward, ana, upsilon, wint, kata, delta, and zant.<br/> Goto:<br/> <a rel="nofollow" href="http://en.wikipedia.org/wiki/Fourth_dimension">http://en.wikipedia.org/wiki/Fourth_dimension</a><br/>
a tesseract is the 5th dimension
The 4th dimension is just another direction to move in, its a spatial dimension.
I've often wondered if there would be any interesting weirdness resulting in a toroidal transformer wrapped with wire similarly to a Hopf fibration. Obviously, it wouldn't quite be the same thing since wire would cause the fibers to intersect, but I'm convinced there has to be some difference in efficiency or some odd property not present in your standard iron doughnut. Just a thought - maybe you've tried it. I might if I get bored enough one day.
for a great way to understand how to perceive another dimension watch "flat land" available @watchmovies.net
First off Mikesty: It's a Mobius Strip, not a Nobius Strip. And they are only mathematically achievable. In real life the object must be created with something that at one point had two planar surfaces, making the 3D reality unattainable. Second off the Tesseract with a "cube inside of a cube" does not satisfy the needs of elementary geometry. A square by it's definition is a parallelogram and a rectangle. The definition of a rectangle is that all angles in the shape are 90 degrees and the definition of a parrellelogram is that all sides are parallel. Take a look at the 3-D renderings of the cube within a cube and tell me what you see wrong with this? No imagine a 4-D shape with nothing, but right angles and parallel sides and tell me your brain doesn't blow up. It's like posing the question of where the universe ends....if it ends what's next? If it is contiguous ie. a sphere, then where does that sphere reside? Your mind is incapable of grasping infinity and also of grasping a fourth dimension. Until you can learn to accept that fact, no knowledge can be gained.
you just blew my mind with the last few sentences... makes me wish i was on lsd or acid or any other hallucinogenic we could then have a 3 hour long conversation about how the world will end XD
Let me elaborate a little more for your psychedelic needs. Think about how the solar system is set up, and how the traditional atom is set up..... Positively charged center with negatively charged electrons orbiting the nucleus. Sun = Emits energy, Planets = absorb energy ie. positive, negative. Now consider my earlier comments about grasping infinity. Are you a Universe, your couch, your table, your computer, are these all universes? They are made up of atoms. This is highly unlikely, but I just wanted to trip you out again.<br/>
lol 10 hours to late i robotripped last night and that would have fun to read but this is the funniest paragraph ive ever read i hope you enjoy it... "You could end up walking out your room naked with a beanie on your head mumbleing about how cold it is while your eyes are the size of frizbiez and you begin to try to make yourself a bowl of corn flakes using tongs, oven mitts and a jug of pineapple juice while all that time your parents and staring at you in disbelief ready to call the rehab to get you off those evil drugs."
lawl
gimme mah bukkit beetch!
the whole time shouting "THEY BE STEELIN MAH BUKKIT"
LSD and 'acid' are the same thing.
k?
To elaborate on my above comment, I would like to add that in the parameters given, the popsicle stick representation <strong>may</strong> be accurate given the comparison of the cube drawn on a piece of paper. It's Hard to tell because of your brain's inability to comprehend the 4th dimension.<br/>
ow.i think i sprained something.
About This Instructable
59,020views
16favorites
License:
Bio: I'm a figment of my own imagination. ---- To Win the war on Terra Means to END the WORLD. How about a nice game of ... More »
More by VIRON:How to Make more game memory / cards for the Hydra Game Console How to MAKE PV Solar Panels Make a Brass Soldering Iron Tip (, How I ...)
Add instructable to:
