Introduction: Make a 1/4 Inch Adaptor Necklace
Ever wanted to have an item that was wearable, stylish and useful? Well, here you have it. This necklace can be used for its original purpose and as a form of expressing your love for audio-related stuff .
All you need is:
A ball chain
A 1/8 Inch Female (3.5mm) to 1/4 Inch Male(6.35 mm) Audio Adaptor
Dremel/Cordless drill
A 4mm drill bit
A drawing pin or pointed knife
WARNING: depending on which brand of adaptor you have, you may have to alter the steps to suit it, so that the adaptor is still usable when drilled. Some adaptors have completely metal insides, and without a metal drill bit, this instructable won't work.
All you need is:
A ball chain
A 4mm drill bit
Step 1: Press Drawing Pin/knife Into Either Side of the Adaptor
First of all, press your pointy tool of choice into either side of the adaptor, as to leave a mark, similiar to a pilot hole. I recommend doing this near the top of the insulated part of the adaptor, but not too close to the entrance hole of the 1/8 inch jack. 4 to 6 mm is ideal.
Step 2: Drill
Drill a 4mm hole straight through the adaptor, going through the pilot dots.
Try to avoid the metal areas. This may take some trial and error.
Step 3: Thread Ball Chain Through and Wear
Grab your ball chain and thread it through the holes you just drilled.
Loop the chain around you neck, secure the end, and wear. Enough said.
Hope you enjoy wearing this as much as I did! :)
Suggestions welcome.
