All you need is:
A ball chain
A 1/8 Inch Female (3.5mm) to 1/4 Inch Male(6.35 mm) Audio Adaptor
Dremel/Cordless drill
A 4mm drill bit
A drawing pin or pointed knife
WARNING: depending on which brand of adaptor you have, you may have to alter the steps to suit it, so that the adaptor is still usable when drilled. Some adaptors have completely metal insides, and without a metal drill bit, this instructable won't work.
Remove these ads by
Signing UpStep 1Press drawing pin/knife into either side of the adaptor
Instead of an adaptor i used the end of my old not-working-anymore earphones and it looks awesome.! x)
Oh, and I know you probably get this waaaaaaay too much, but: have you made a bomb yet? :P
I ended up removing the out and inner "insulation", but it had no effect.
I do recommend using a step drill bit to avoid denting the adapter while drilling.
This is pretty cool, yet, all i have is a mini 1/4 to 1/8 adaptor.
