Remove these ads by
Signing UpStep 1Materials
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
All Steps Viewing
Just don't make this if you use an arc soldering iron like the ColdHeat.
Electricity running through steel wool is bad D:
Picture of soldering iron stand and sponge:
http://www.instructables.com/files/deriv/FV4/RRAH/F41RXKUZ/FV4RRAHF41RXKUZ.MEDIUM.jpg
Note also how iron is not held in a vertical position to avoid heating up the handle excessively when the iron is idling.
If I really need to steel wool a tip I just wipe a piece of steel wool over the tip myself.
Also, quit being such a baby with puny iron fumes. If you need a fan for an iron what would you need running an 800 pound wave solder pump?
http://images.google.com/images?hl=en&um=1&q=wave+solder+machine+pump&sa=N&start=180&ndsp=20
Also, please note how the irons are held in an essentially horizontal orientation in these two holders pictured. One I made, one manufactured commercially. Do you know now?
1. You do not ever need a fan to run one soldering iron in a room.
2. I have found a wet cellulose sponge to be a good tip cleaner if the tip is hot. Keep a small squeeze bottle of H2O handy to keep the sponge moist. If you do not have a soldering stand with a place for a tip cleaner, get a saucer or metal jar lid, a piece of wet sponge, and you are ready to clean the tip as needed.
3. A professional grade soldering iron of useful wattage should be held in a near horizontal position between soldering operations. It will get too hot to hold comfortably if left nearly vertical.
4. Most beginners start off with an iron that does not get hot enough to consistently produce good solder joints.
while I'm sure your lungs are quite resilient to the burning flux fumes, I know several people who cannot stand the smell and I'm not going to go and tell them to quit being a sissy because it won't kill them. That said, you have to understand that using a fan never hurts.
Because when you are really being overcome by flux fumes that is what it is like!
I've been in both situations so I know the difference. When I run this thing I need to ventilate, but its a LOT bigger than a soldering iron now isn't it? Honestly I like the smell of flux off an iron, its not bad.
I wasn't kidding.
I know 2 different people (not related) whose airway constrict at the inhalation of solder fumes. Now, would you kindly bugger off? Obviously this guide wasn't made for you and I don't know what you're trying to prove, telling people that they should macho up and suck up some acid fumes.
