3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a 240V MOT high voltage power supply with 120V transformers
I love to play with MOT's but the only breaker i have to power them off of it only rated for 15 amps, so i decided to see if I could power them off a 240V outlet my dad made for his welders and air compressor and sure enough, it works! So here i will show you how to make a great MOT power supply very easily and for a very low price!
*A MOT can kill you instantly or give you a really nasty shock and they are not toys, I have been shocked by one and it was freaking scary and painful so BE CAREFUL! i am not responsible to any damage caused!
Step 1You will need
you will need
Two MOT's
A light switch
A inlet from a computer power supply or something like it
A PFC capacitor (optional). 20uF at 250V+ should work just fine
Some .250" female spade connectors (bag of 50 for $2.20). You will also need some smaller ones for the inlet but I don't know what size
Some 14 awg wire. Speaker wire or an old power cord will work just fine
A 12" piece of 2 x 4
A soldering iron and solder
A drill
Some screws. I used #8 x 1/2" screws from Home Depot
7 comments
May 12, 2012. 1:07 AM-max- says:
they make the wall plugs like that for a reason. in that type your showing in the last picture, both 'prongs' are sideways, or flat, and when the plug itself when it has two sideways prongs, it is supposed to go in a 240V 1 phase outlet.
The vertical part on the left side indicates that it can handle a good bit of current.
you should never try to do what you did, because it is dangerous. (but then again, so is this project!!!)
you can pick up those 240V adapters from a hardware store like Lowes or Home Depot.
May 16, 2012. 5:09 PMR.A.T.M says:
What happened to jimmy
May 17, 2012. 1:38 AM-max- says:
i think his parents kicked him off youtube. i realy have no idea what-so-ever.
May 16, 2012. 10:02 PMR.A.T.M says:
He just vanished
Jan 5, 2012. 5:23 PMvger13 says:
i like working with mots also but make no mistake they are deadly and the caps are very dangerous,i have been running a six mot stack on my coil for years,but your set up as is ..is very dangerous
Jan 10, 2012. 9:43 PMjon002 says:
do you have scrap
Jan 11, 2012. 3:29 AMvger13 says:
not sure i get your meaning...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
63
Author:Jimmy Proton
