Step 4Soldering The LEDs
The last time I soldered a matrix I used lots of little wire jumpers which was a pain to solder, so this time I was a little more creative and came up with this way.
You need to bend the positive lead of the LED down towards the other ones and make a column, and snip off the leads you didn't use and try to make the connections as low as you can get, and you do this to all of the positive leads.
Now the negative leads are connected in a column and thats make soldering tricky because the positive rows are in the way, so you will need to make a 90 degrees bend with the negative lead and make a bridge over the positive row to the next negative lead, and so on to the next LEDs.
Now I will not explain how to solder the shift registers and all the parts because every one has hes own style and methods.
Thanks
Joe
Thanks.
hardware wise you need to add 3 more shift registers and one more transistor and some more resistors.
I got one question about the project
I want to make the display bigger 48x6. What modifications i have to do to the schematic
my e-mail :stavro1991@hotmail.com
Thanks
