3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a 3 degree of freedom 'hand' to help with soldering / gluing work
Make a 3 degree of freedom \
How to make a new three degree of freedom hand for your 'helping hands'. The design allows you to make custom, switchable end-pieces (in addition to the standard alligator clip).
Step 1Find parts lying around
find parts lying around
you'll need:
three screws,
four nuts (appropriate to the screws above),
two big washers,
'ZapGel' (gel cyanoacrylate) and 'zip kicker' (a solidifying accelarent)
(http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCX45&P=M)
-OR-
ShapeLock
http://shapelock.com/page2.html
alligator clip
a thin piece of metal/plastic that you can drill holes in (I used a lego piece with holes already in it)
optional:
two capped nuts (I don't know what these are actually called, see picture),
5 comments
Oct 22, 2007. 7:04 AMHandsome-Ryan says:
The heads of acorn nuts will break off if you keep tightening a screw into them. I learned this by accident and had to go buy a new nut for the project I was building but it would be perfect for intentionally removing the dome part as you are doing.
Jun 17, 2006. 10:30 AMJunkyard John says:
I see one problem with the glue. If you're are soldering for a long time, and using the arm as a heat sink, the clip will get vary hot and melt/burn the glue. Safety hazard?
Jun 16, 2006. 6:34 AM_soapy_ says:
If you had a small ball-joint, that would work too. Or a flexible/bendable wire with a gator clip on the end might be a useful addition.
Jun 14, 2006. 11:49 PMElectricJ says:
Hey, this looks like it would be pretty handy! Thanks
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
81
Author:leevonk
www.leevonk.com
