Introduction: Make a 3D Printable Walking Robot!!
Picture of Make a 3D Printable Walking Robot!!
DOWNLOAD 3D files here!!
http://www.thingiverse.com/thing:793791
You will need:
  • 3-speed crank axle gearbox
  • Screw diver
  • Scissors
  • Appliers
  • sponge tape
  • Battery box and a battery
  • Small conductor wire
  • Screws
  • 3D printed parts
  • Hammer
  • Clamp
  • Hack saw (for cutting metals.)
  • Drill bit (optional)
Step 1: Assemble the Gear Box.
Picture of Assemble the Gear Box.
Assemble the gearbox by following the instruction included in the gear box kit. Cut the shaft to 47mm, and the gear box should be on the slowest speed.
Step 2: Attach the Gearbox to the Main Frame.
Picture of Attach the Gearbox to the Main Frame.
Using a screw driver and screw, attach a gearbox you assembled to the main frame.
Step 3: Attach a Battery Box.
Picture of Attach a Battery Box.
Attach battery box using sponge tape.
Step 4: Attch Parts (1)
Picture of Attch Parts (1)
Attach the main shaft drive hook to the main shaft. Make sure that each hooks are facing the opposite way.
Step 5: Attch Parts (2)
Picture of Attch Parts (2)
Attch the leg and the upper hook to the main frame. If the parts doesn't go through some of the parts, you can use a drill bit to make the hole bigger. For the upper parts, you will use a bigger pins, and for the bottom main hook, you will use the smaller pin.
Step 6: Done!!
Picture of Done!!
We are done!!
Thanks for viewing my project.
EvolvedAwesome (author)2015-04-26
Awesome!
Thanks. Thanks for always supporting me by putting these positive comment!!
About This Instructable
887views
10favorites
License:
More by Ntrobotics:Pancake CNC Machine (Turn Your CNC Into a Pancake Machine)IoT Pet FeederMake an Electric Violin
Add instructable to:
