3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a $5.00 "Space Pen" for your wallet
Make a $5.00 \"Space Pen\" for your wallet
Having a writing implement handy when you need it is a good idea, but keeping a bulky pen in your shirt or your pants pocket can be a drag, especially when conventional pens leak. Your wallet is a natural place to keep a pen but just about anything available commercially is too big. So, make a Space Pen for your wallet. It's small, writes every time you need it, upside-down, and probably under water, too, although you'll have to test that yourself.
The "NASA Space Pen by Fisher" is a cool pen that retails in stores like Staples and Office Depot for about $22 in its basic, chrome-plated version, up to near $50 for the special, "signature" version. It is the famous pen the astronauts supposedly used in the space program. The pen uses a sealed, gas-pressurized ink cartridge, which delivers the ink at a perfect flow without clogging--important for a pocket pen. The problem is the NASA Space Pen body is very thick. It feels like a carrying around a big, chrome-plated bullet in your pocket.
It's way too thick to slip in your wallet, too. Overall not a good traveling pen, even at that price point. But, interestingly, the same outfits that sell the pens also sell the refills and they are a fraction of the cost: about $5.00. The one to look for is labeled, "Fisher Pressurized Space Pen Refill - SPR-F". As near as I can tell all the pens use the same, $5.00 refill.
(link: example of refill at online store)
With a bit of heat-shrinkable tubing, a pocket clip taken from a discarded mechanical pencil you can have a cool pen that keeps in your wallet nicely. And since it uses the pressurized, Fisher Space Pen refill, it isn't likely to leak in your pocket.
And, it writes upside down. So, let's get to work. This one will take about five minutes.
Step 1Adding the heat-shrinkable tubing
The tubing makes the pen cartridge a bit more holdable then just the bare metal. I used black tubing for mine, but it can be obtained in various colors. Radio Shack sells a very reasonably-priced assortment in various colors. The black tubing used in this project was ordered in bulk from Mouser Electronics. For this, use 3/8 inch tubing. Cut the tubing with an X-ACTO knife, leaving about 1/4" past the first ridge in the point, or about 3/4" from the tip.
87 comments
1-40 of 87next »
Aug 7, 2011. 5:09 AMtakchess says:
I have the expensive habit of losing space pens. This is a great alternative. thanks! Now you need to work on the treker replacement which is a space pen keychain version. 8)
Jan 22, 2011. 9:51 PMValeil says:
This is an amazing instructable, but I have one question.
Couldn't you put the clip on before the tubing, so that it would be a safer hold? Just curious(:
Mar 13, 2011. 1:48 PMValeil says:
Tried this, it sort of works. I used a bobby pin for the clip, and had to make sure the tubing REALLY shrank between the pin and the pen(heh, wordplay.) Overall though, great instructable :D
Apr 23, 2010. 7:39 AMsalemalastor7 says:
 do u mind telling me where you got that mechanical pencil? it looks really nice and i want to get one,. (pen is also a great idea, i made one xD) thanks !
May 3, 2010. 1:00 PMsalemalastor7 says:
 thank you kindly Doctor_wu. ill bet they are made in china now or something, but either way i appreciate the information xD
Nov 16, 2009. 10:05 PMKryptonite says:
I made one of these out of a conventional refill before I saw this and I must say, yours is much better!
Also, something that I once heard before about these pens, NASA spent $100,000 on working on these for astronauts. Russians used pencils.
Jun 19, 2009. 9:46 PMmemyselfand1 says:
Can you get these in Australia? I've never seen them.
Mar 8, 2009. 8:02 PMOryctolagus habilis says:
Great new use for heat-shrink tubing! However, Fisher now makes the "stowaway" model, for $12, which is basically a refill with an aluminum tube to reinforce it, and a cap. I like their $14 "military" model, which is just shy of a regular pen length, but narrower than the "bullet" model; and it's a click pen, so no cap to worry about at all.
Oct 7, 2008. 6:57 PMCarStalkerZ says:
does anybody know were i can get a pocket heatgun
Aug 31, 2008. 2:14 PMducktape1 says:
This is an awesome idea... but after 2 weeks of having a pen always on hand the tip sheered off the pen leaking its contents all over my wallet =( BEWARE!!
Sep 6, 2008. 10:15 AMR4Man18 says:
I dont suggest keeping a pen in your back pocket, if you keep your wallet in your back pocket just keep the pen in a side pocket. been doing this ins for a while and had that problem once when I switched it around ive never had that problem again.
Sep 6, 2008. 5:50 PMducktape1 says:
thanks for the solution i think ill stick with a golf pencil though (seems cleaner)
Jun 5, 2008. 12:41 PMairsofter2 says:
this is really cool, but is there any way that you could develop a cap for it, because I am more of a pocket pen person than a wallet
Sep 5, 2008. 1:58 AMDamionLee says:
I thought this was a great idea, and also wanted a cap so here's what I have done. With the Fisher refill there is (certainly in the UK) a small white piece of plastic. With a small screwdriver you can open up the end of it a little wider so that the nib of the refill fits through it. Then with a knife I trim the end of this down so that it is quite smooth. (This also makes the pen easier to write with). Now, I also liked the Mont Blanc in a Pilot G2 Instructable, so having done that, I have the black plastic cap from the Mont Blanc refill. This makes a perfect pen cap for the Fisher refill.
Sep 3, 2008. 3:23 PMGoodhart says:
I am wondering if a regular tapered BIC pen cap would work ?
Jun 10, 2008. 6:52 PMcoopgrl88 says:
you could probably use the insulation to a wire that fits the gauge of the pen head. put a gob of glue on one end to seal it up so your pen won't dry up. or something along those lines...just brain storming.
Jul 25, 2008. 2:38 AMWho-Cares says:
Nice Instructable. Instead of using a clip from an old pen you could use a bobby pin and put one end under the heat shrink tubing.
Jul 10, 2008. 12:37 PMXTTX says:
Great idea! Just made two of them.The only issue I'm having is getting the clip to fit. I have a similar clip to what you have; however, I can't get the fitment right, it just slides off. I'll play around with it. Thanks for the idea :)
May 29, 2008. 6:28 PMc6h12o6 says:
I heard that NASA spent a large budget on this years ago and that the russians just developed the dispensing pencil, in half the time and at a fraction of the cost. Hmmm might just be one of those urban legends tho. V cool idea for instructable though, handy.
Jun 1, 2008. 2:15 PMJoelDude says:
actually NASA spent like 100k+ to invent a preasure ink pen so the ink would come out, the rusians finally talked about the problem with nasa, they discovered that the rusians used regular disposable pencils
May 30, 2008. 11:34 AMdespoteuodia says:
Its only a myth. Graphite (pencil lead) is conductive and would cause shorts in the electronics. also, regular ball point (cheapo Bic or papermate etc) will work in space. The ink is water based, so its adheasive and cohesive. upside down they dont work because gravity would work against the pen, but with no gravity, cohesion and adhesion provides enough force to move the ink. Nasa did spend a large budget on office supplies, but thats because they buy everything in bulk.
May 30, 2008. 8:21 AMhithisishal says:
I think that pencils were deemed unfit for the space program. The small conductive graphite shavings would float everywhere.
May 30, 2008. 7:01 AMadamthiede says:
USA: Let's develop a secret agent underwater-upside-down-write in space pen! Yeah! Russia: That's great... let's use a pencil!
Sep 18, 2008. 2:16 PMkeastes says:
we're Americans we over-engineer everything, oh and wtf is K.I.S.S. supposed to mean anywho
Feb 10, 2009. 10:22 AMoniman7 says:
Keep it simple, stupid. Or something like that. Personally, I think a pencil would have worked just as well.
May 29, 2008. 9:44 PMrule001 says:
Jup, it actually is thrue! NASA spent milions of dollars on research developing this pen...and the russians solved the problem by just taking a pencil with them. This pen is one of NASA's greatest embaressements. (..but it does write pretty good, even thrue oil spils, grease,...)
May 29, 2008. 11:31 PMkaens says:
It's actually not true, see here, although astronauts did use pencils for a while.
May 30, 2008. 1:04 AMrule001 says:
...and how much did NASA pay Fisher to claim this? ;) (It wouldn't be the first dumbass american gouvernement expence that needs to be covered up,...and probably not the last ;) ) ps:...ok, ok, ..i might be a conspiracy theory nut :D
Sep 5, 2008. 6:17 AMFoxtrot70 says:
rule001 - Oh, surely NOT! After all we didn't land on the moon...the flag waved in the wrong direction! How's that for wasted millions or billions. A Million Dollars here, a Million Dollars there...after a while you're talking REAL money! - Former Ill. Senator Everet Dirksen (deceased)
Sep 14, 2008. 6:58 AMOompa-Loompa says:
And how can you prove we've never landed on the moon again?
Sep 14, 2008. 7:34 AMFoxtrot70 says:
It is a matter of my skeptical being. Of Big Government and Big Business i.e., I applied for SSI,I am 57 keep in mind I have paid into SS system for the last 41 years and the time I need assistance..."Oh! We just can't help you." When I go to retire which will probably be forced, rather than volentary, by who ever happens to be employing me. The way things are going SS will most likely be bankrupt by the time I reach 65 or some weisenheimer in congress will reset retirement age to 72. This is in hopes that the applicant will die before any benefits are required to be paid. So, yeah I have doubts we ever went to the moon. One way to prove it beyond any doubt would be to turn the Hubble Telescope on the moon. I grew up in Missouri where the State Motto is: "Show Me"... if there is nothing to hide "Show Me!" Show Me - The Moon Rover; Show Me - The Tranquility Base; Show Me - The Flag; It surely can not cost all that much to enter a few data commands to swing the Hubble around and put everything to rest. If the moon is too close for the focal length of the Hubble there are any one of dozens of scopes on earth that could do the job! SHOW ME!
Sep 14, 2008. 7:46 AMOompa-Loompa says:
They did moon landing on mythbusters. There were a few ways they proved it. 1. pictures of footprints on the moon were shot down by saying that they wouldn't form in a vacuum. After testing, footprints could be made in a vacuum. 2.The flag can't wave in a vacuum as it did on the actual footage. They proved that a flag's momentum is enough to keep it waving in a vacuum after being jostled around by the astronauts. 3. They proved that the way the astronauts bounced around could not be perfectly replicated on earth, and had a specialized jet thing let them experience low gravity, where they could perfectly replicate the bouncing. 4. The astronauts were said to have placed reflective equipment on the moon's surface. After sending laser signals out to the moon and receiving them back, they proved this was true.
Sep 14, 2008. 8:56 AMFoxtrot70 says:
Another way to verify is since we have satelites orbiting the moon for surface mapping. Why not have one of them focus on the Lunar lander and provide pictures of our space junk. After all we paid millions for it. SHOW ME!!
Sep 14, 2008. 9:30 AMOompa-Loompa says:
Um, IDK, but we did land on tha moon.
Sep 14, 2008. 10:54 AMFoxtrot70 says:
Oompa I went to the YouTube site and viewed the MythBuster episodes. I do concur with you we did land on the moon. It would seem to add to the confirmation if a satelite pic weather from Hubble, Moon orbit mapping satelite, or Earth based were available.
Sep 14, 2008. 12:11 PMOompa-Loompa says:
True, but I don't think if we ask they'll just give us a picture of the moon, so for now, we'll just make due.
May 30, 2008. 8:15 AMgitemstevedave says:
In the link above, they explain that Nasa paid/pays retail for them. Fischer owns the patent, so there's nothing to "claim".
May 30, 2008. 6:47 AMkaens says:
Ha. Probably a lot.
1-40 of 87next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:doctor_wu
