Make a Adjustable Brightness Flashlight!
Published
Introduction: Make a Adjustable Brightness Flashlight!
About: ahh, its nice to be back again :D
Just make it, whether its for seeking about,or scurrying out about, its perfect and pocket size!!!
Step 1: YOU EXPECT TO DO THIS WITHOUT MATERIALS?heck Not!
k, you need a 501 pot resister(from a old non working printer will be good...)
A pole switch (from Radio shack)
A 2 AAA battery holder with cover(from radio Shack)
2 AAA Batteries
Good idea to have a bread board for a prototype!
2 core wire(black and red)
Glue
And Lots Of Electrical tape LOLZZ
also, a any coler led that will work on 2 AAA batterys(FROM RADIO SHACK!!!)
A Master Soldering Skill With A Soldering Pencil
this is because we will be soldering wires on small terminals on the parts and soldering wires together!!
Step 2: Lay Out Your Parts!! in This Step, Have Your Bread Bord Handy!
I WILL REFUSE TO TAKE THIS APART!!! I STRUGGLED ALOT GETTING IT TOGETHER!!
first attach the battery holder to the positive and negative parts of the the power on the bread bord.
just follow this circuit diagram and make it on your breadboard
after its done test it by putting in the battetrys and turn the switch on. try messing with the pot with a screw driver.see if it dims and brightens,if so, your ready for next step, if not,troble shoot!
Step 3: Sodering Time!
solder the same circut as before using your sodering skills...
Step 4: Lots of Tape and Glue!!
k.. we did that, time to fully assemble!!!turn the battery holder over cover side down and glue the pole switch and the pot switch,and the led some where, let it sit for 2-days for best results
then tape all wires down,and run a test. if it dosent work, troble shoot
Step 5: All Done!
yay were done. pls vote for this becouse you can put it on just about anything!!!!good luck!
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    3 Comments
    Dude this is just the thing i wanted.................Thanks
    No offence but it would be easier with a piece of card piece of foil make a 3v battery conecter with one flap foil up so you press to tun on then just some foil towards each Led Pole it'd look a helluva lot nicer and would be smaller i may make a i'ble on it actually .
