Make an Altoids Tin Portable Helping Hands (with Fume Extractor) by legwinskij
Hi there this is my first Instructable so i hope you will like it.
Few days ago i've decided to create this cool Altoid Tin Portable Helping Hands. I'm soldering a lot so i need helping hands but most of the time i'm doing just small stuff like soldering an LED or something like that and i don't like original helping hands that much. So i've decided to create something small, portable and useful.
Step 1: Gather your parts and tools
Main Parts :
1 - Altoids tin can
1 - 12V Fan,best would be 4cm because we need to put him inside the Altoids tin
carbon filter [you need to fit him on the Fan]
4 - Aligator clips
1 - SMD White LED
Side Parts:
1 - 560 Ohm rezistor
Wires [i've used wires from FTP cable because they're good for bending]
1 - Switch
1 - Micro 2 position Switch
1 - Connector to 12V [i've used 3,5mm mono jack connector]
Insulating tube
Tools:
Soldering Iron
Solder
Plate shears
Wire cutter
Desoldering pump
kevrack1999 says: Aug 22, 2012. 3:20 PM
Hey i was just wondering where you get the alligator clips and the price. Please reply when you can or anyone else with helpful info. Thanks! ( By the way this is a very nice and detailed insructable!)
legwinskij (author) says: Aug 22, 2012. 5:34 PM
(removed by author or community request)
legwinskij (author) says: Aug 22, 2012. 5:35 PM
Hi I bought alligator clips here
http://www.soselectronic.com/?searchstring=alligator&str=12
you should be able to see prices and various versions and thanks :)
tqwerty says: Jul 28, 2011. 2:58 PM
Does everything fit in the box after its all attached?
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
