This can be used to grind chemicals to a very fine grain or to polish rocks.
Wiki says "A ball mill is a type of grinder used to grind materials into extremely fine powder for use in paints, pyrotechnics, and ceramics."
Many instructables refer to United Nuclear Ball Mills. Their small ball mill cost between $70 and $80 dollars.
For no more than $30 and in 5 minute you can build a ball mill of appreciable performance.
Check out my other Instructables:
MAKE A HIGH VOLTAGE SUPPLY IN 5 MINUTES
Hack The Spy Ear and Learn to Reverse Engineer a Circuit
Super Easy E-mail Encryption Using Gmail, Firefox and Windows
Make a Rechargeable Dual Voltage Power Supply for Electronic Projects
Make a Voltage Controlled Resistor and Use It
SODA CAN HYDROGEN GENERATOR
ballmil.wmv557 KBStep 1: What You Need
1. A rugged container (You can use PVC pipes or big plastic bottles)
2. An electric screwdriver (these are fairly cheap, I got mine for $10)
3. A bolt, a nut and maybe a washer.
4. Epoxy putty.
5. Steel or lead balls which in my case I substituted with screwdriver bits that I got for $3.
6. A vise clamp to hold down your ball mill.
Step 2: Bolt the container
Step 3: Join the Container to the Electric Screwdriver
Put a little putty on the bolt first. Insert the bolt into the screwdriver's bit holder. Cover the whole joint with putty. The more putty the better the ball mill stays together.
Step 4: Clamp the Assembly to a Table Top
I use a popsicle stick to hold the screwdriver button down. I jam it between the clam vise and electric screwdriver (see video). But that depends on your electric screwdriver.
Visit Our Store »
Go Pro Today »
Cordless drills with dead battery packs would provide an endless supply of variable speed motors for this project. (I have three on-hand.) All I have to do is cobble up a connection to the power supply from a dead computer.
I've been wanting to polish some rings. Thanks for the idea.
I plan to make paper machie. I want to make a very fine paper pulp. While I doubt this is flammable, I would like to hear any comments on this as well. Who'd a thought flour was explosive?
i dont have the money for the mill or the shipping.
unitet nuclear is great if u live in u.s.a. but i lie in europe.
and why would i buy one if i have all the parts lying around?
