3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a Ball Mill in 5 Minutes
This is for all the pyro nuts that I came across on Instructables.
This can be used to grind chemicals to a very fine grain or to polish rocks.
Wiki says "A ball mill is a type of grinder used to grind materials into extremely fine powder for use in paints, pyrotechnics, and ceramics."
Many instructables refer to United Nuclear Ball Mills. Their small ball mill cost between $70 and $80 dollars.
For no more than $30 and in 5 minute you can build a ball mill of appreciable performance.
Check out my other Instructables:
MAKE A HIGH VOLTAGE SUPPLY IN 5 MINUTES
Hack The Spy Ear and Learn to Reverse Engineer a Circuit
Super Easy E-mail Encryption Using Gmail, Firefox and Windows
Make a Rechargeable Dual Voltage Power Supply for Electronic Projects
Make a Voltage Controlled Resistor and Use It
SODA CAN HYDROGEN GENERATOR
Step 1What You Need
What You Need
You need
1. A rugged container (You can use PVC pipes or big plastic bottles)
2. An electric screwdriver (these are fairly cheap, I got mine for $10)
3. A bolt, a nut and maybe a washer.
4. Epoxy putty.
5. Steel or lead balls which in my case I substituted with screwdriver bits that I got for $3.
6. A vise clamp to hold down your ball mill.
138 comments
1-40 of 138next »
Nov 8, 2011. 10:22 PMlisass says:
That is great.
Dec 25, 2010. 1:43 PMhardlec says:
I may well be able to find a power drill at a resale shop, or buy an inexpensive one for the purpose. Any feedback on how well a power drill motor will hold up to being run for 24 hours continuously?
I plan to make paper machie. I want to make a very fine paper pulp. While I doubt this is flammable, I would like to hear any comments on this as well. Who'd a thought flour was explosive?
Apr 19, 2011. 6:32 PM7654321 says:
I seriously doubt paper will ignite. Also, if you can get a motor that plugs in, you dont have to worry about battery life. I got my motor for mine from a fan.
Jul 25, 2010. 9:28 PMDELETED_madscientist167 says:
(removed by author or community request)
Nov 19, 2010. 1:49 AMWareOuttaHair says:
Rocks can spark so probably not a good idea unless you plan to use it for crushing seed for your birds or something.
Jul 27, 2010. 3:51 AMskicero says:
Use shotgun shells in place of the balls. Buy a pack of buckshot (make sure they are not steel if your mixing anything pyrotechnic), break open the shells and use the pellets.
Nov 18, 2007. 11:35 PMMrBrownstoo says:
hmm... methinks you should support the container. lead balls are heavy and (I'm assuming most people will want to make gunpowder with this so they'll have to use only lead balls) the current setup is going to make the screwdriver wear a lot, and the bottom of the container isn't going to last very long... I like this idea though, I haven't found a suitable motor to drive my ball mill, they're all either too weak or they're way too fast.
Jul 26, 2008. 2:44 PMcomander01 says:
Supporting the container world be tricky, but posiible. Try something like this. Not quite sure what you'd make it out of, but something along that idea.
Aug 2, 2008. 4:08 PMRiddleOfSphinx says:
OR, you could just attach a bolt into the cap like he did for the bottom. Make a triangular piece of wood. Drill a hole for the bolt to fit through. And find some way to support the piece of wood? Seems like it would work to me, could even make your own cradle to support everything for that matter :P I'd never use something like this so have no need to make one, but that would be my advice :D
Aug 3, 2008. 1:19 PMcomander01 says:
Thx, that looks much easier to make than my suggestion. Ill keep itmin mind.
Aug 4, 2008. 4:11 PMRiddleOfSphinx says:
No problem, hope it works for ya, I don't have the materials to make one myself :(
Jul 20, 2010. 5:38 PMmuberblob says:
shotgun balls work really good if they are of the lead variety
May 16, 2008. 3:36 AMJJrulz says:
Can you only use lead if you intend to make black powder? Why does it have to be lead?
May 16, 2008. 2:44 PMdemolitionNerd says:
No you can also use some of the new ceramic balls but they're even more expensive than lead balls. The reason you have to use lead or ceramic balls is because the won't spark when they slam together in the ball mill. Which if you were making black powder or another explosive chemical would otherwise result in an explosion.
Oct 9, 2008. 11:57 PMnetbuddy says:
Powders can explode due to the mix of fine particles and air. If you have ever worked in dangerous situations and had the "Health and Safety" training videos, you may have seen the "Exploding Flour Lorry" video. You wouldn't normally associate flour as in the stuff you bake with as being highly explosive. The video shows a flour truck being detonated, the film crew are about half a mile away when they ignite the truck contents. They couldn't fine anything of the truck other than a mangled chassis and one set of wheels. The rest of the truck had been blown to bits. So when grinding, you are advised to follow some basic H&S protocols or you could end up seriously hurting yourself, killing yourself or find the local anti-terrorism squad kicking your door off and holding you under the prevention of terrorism laws we all now live under. Happy grinding.
Oct 14, 2008. 5:05 PMdemolitionNerd says:
True but the chances of that happening in the mill, because it's in such a small tight space (not saying that it won't happen, but that it is very unlikely).
Oct 15, 2008. 4:35 AMnetbuddy says:
Go ahead, blow yourself up. A bullet only needs a few grams of powder, so what do you think half a pound could do to you?
Jan 4, 2008. 8:24 PMrecon506 says:
try using something like an old drill press motor, or you could check out one of the tesla motor instructables, and use a gear system to put into low speed - high torque.
Feb 28, 2010. 8:18 AMChristorium says:
 The sulphur in BP only serves to reduce the ignition temp. BP works fine without it. First grind the charcoal but add a little water to keep all the dust together. After adding the saltpeter, keep the mixture wet to reduce the chance of sparks and to get a better mix. Use only lead, copper or brass balls. The BP can be dried afterwards.
Feb 21, 2010. 3:14 PMtheghillieman says:
 Would large lead shot work? Its only like $1.50 for a couple pounds at a near by metal shop.
Feb 17, 2010. 2:03 AMnutsandbolts_64 says:
How much does the epoxy putty cost?
Apr 5, 2009. 10:36 AMfatboy106 says:
Jan 12, 2010. 5:59 PMKryptonite says:
You'd have to gear it down, you don't want it going too fast.
Jan 12, 2010. 5:56 PMKryptonite says:
Gotta make sure the "balls" you use don't spark.
Aug 29, 2008. 2:49 PMmlapoi7995 says:
There are many ways this can be done. you could build a simple jig out of plywood to mount the motor and the entire drum assembly. you can also use bearings scarfed from old roller blades for the end shaft. motors can come from anything but if you use an AC motor I would suggest you get a controller from Harbor Freight to control your speed its just a plug with a potentiometer built in and is used to control the speed of a router...If you wish to use DC motors one of the best sources is Goodwill or any thrift store, look for old calculators that use paper rolls. They have heavy duty motors in them and if you go even older on them they have small AC motors...I also scarf motors from printers, washers and dryers for AC motors. You get a motor turning 1725 RPM and about a 1/4 HP. Thanks for the Instructable my wife wants a rock tumbler so you have given me a way to do it cheaply with parts I already have. ANd a way for me to polish metal parts.
Nov 16, 2009. 11:51 PMrandyclark747 says:
You know what crossed my mind for grinding media is heavy steel nuts, instead of steel balls, since they are more commonly available.  What do you think?  Or do you think you can find steel balls at a  auto junk yard, under ball bearing request?
Jan 5, 2010. 6:38 PMHairywiener says:
dude you can use lead balls, much better, you can easily get them at big 5, they are used as weights for fishing, although their not really balls more like egg shaped but whatever
Dec 28, 2009. 9:50 PMstephenniall says:
Im going to build one of these but instead of gluing and wasting a decent screwdriver im using my  cordless drill on ac power and im just going to tighten the nut thats in the Ball mill part Into the chuck and black tie down the handle and leave it
Dec 29, 2009. 10:47 PMstephenniall says:
i will be making a instructable for my version i will post a link when im done
Dec 29, 2009. 9:55 PMstephenniall says:
Im hoping to get in my shed today (locks frozen because of snow) and  hopefully ill be able to do it
Jul 29, 2007. 11:47 PMAdrien says:
Everyone should just buy a ball mill! Its only 60 dollars at united nuclear...
Dec 18, 2009. 4:02 AMlop145 says:
stop spamming!
i dont have the money for the mill or the shipping.
unitet nuclear is great if u live in u.s.a. but i lie in europe.
and why would i buy one if i have all the parts lying around?
Sep 22, 2009. 3:32 PMpanzuman says:
hey will a rocck tumbler work i have one of those so....... will it?
Sep 28, 2009. 12:51 PMsharlston says:
yep itll work youll have to keep it on for around two weeks
Sep 22, 2009. 4:01 PMpanzuman says:
oh and is the more grinding media used the better? i was thinking 75 steel balls for my ball mill they come from sling shot ammo from Walmart :)
Jul 20, 2009. 3:19 PMjester_200x says:
SURE!! everyone can so totally afford to pay 60 bucks and shipping and yeah everyone lives in america. think of those who are unable to come up with 60 bucks plus shipping or people who live outside america with no real ballmill suppliers. come on man...
Dec 31, 2009. 12:47 PMJaycub says:
Yeah $60 is rediculus I got a rock tumbler from the thrift store for a few dollars and am using a mixture of marbles and slingshot ammo (already had both) as the grinding media to mage fine powdered magnalium. It works great.
Feb 12, 2009. 3:14 PMcomander01 says:
Yeah, United Nuclear is great. If you live in the US.
Dec 18, 2008. 10:35 PMkilla696 says:
stuff you we wanna do it our way
1-40 of 138next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
132
Author:Biotele(Biotele)
Make a better Instructable, and the world will beat a path to your website.
