Make a Battery Protection Circuit (low Voltage Cut-off)
40,195
130
6
Posted in TechnologyTools
Introduction: Make a Battery Protection Circuit (low Voltage Cut-off)
About: Hello! I'm Matt and I love making things. I'm always thinking of new ideas and how to make them as awesome as possible, always with a mind to share the process online. Take a look at my profile and see if th...
In this video I will show you how to build a simple lithium battery protection circuit, so you can power your homemade projects without ever worrying about over discharging your battery.
How to use lithium batteries safely: http://www.maxamps.com/lipo-care.php
More info on battery measurements: https://www.youtube.com/watch?v=cxkVxi9P0EA
Items you'll need:
Alarm circuit: http://www.ebay.com/sch/i.html?_from=R40&_sacat=0...
Relay: DSP1a-L2-DC5V
http://www.google.com/search?q=dsp1a-l2-dc5v (select one of the distributors - price is around $5)
Music by Kevin McLeod and Löhstana David
4 People Made This Project!
  • Make it Move Contest
  • Casting Contest
    Casting Contest
  • Microcontroller Contest
That relay only handles 8A. Would this circuit still be suitable for RC projects (such as drones) that can routinely spike to hundreds of Amps current?
6 Comments
I'm hoping to make something like this, could you help me with it? I need a circuit that'll monitor voltage of a battery (3S LiPo, "normal voltage" of 11.1V, minimum voltage of 9V) but, instead of a digital readout, I only need 3 LED's, (red/yellow/green) for "full" (11.1V+) "medium" (11.0V-10V) and "low" (less than 10V), and, since it's for an airsoft gun, I need it as compact as possible, and preferably without the LEDs having to be soldered directly to a board, but rather run on a lead so that I can run them through the gun back to where I want it to be (and be visible). Could you possibly assist with this?
Am I able to use this DSP1A-L2-DC9v instead of the DSP1A-L2-DC5v and just tap into the 3s balance wire? I am unable to get a hold of the 5v in Canada without crazy shipping cost or is there another brand I can substitute. hope you or someone can help
Wow, really great, just what I needed. Could you maybe link to all products used?
Is it necessary to use a 82 Ohm resistor or could I use a 100 Ohm one?
And what kind of push button do you use, as I guess it should be a momentary switch, but it looks like a latching switch?
Very nice! This is a handy item to have.
I've wanted a low voltage alarm for my rc planes, but never sprung to buy one. I'm guessing this could be modified fairly simply to trip a loud buzzer, rather than simply cut off power?
the lipo alarm which is modified in this instructable beeps loudly when the trigger voltage is being reached. this instructable shows how to modify it so it doesn't beep anymore but instead cuts thr circuit. if you simply want an alarm but no circuit cut, just use the alarm behind the link.
To turn the circuit off, wouldn't it be more simple to add a toggle switch between one of the balanced connectors and the monitor, so that when off, it would read 0v and trigger the "alarm" which in turn triggers the relay?
