Have a look at the video:
If you can't see the video, take a look at it here.
But where I live, you can't leave your bike with cool led-lights on it. The lights will mysteriously disappear in a matter of minutes. So I wanted to make a bike light that:
- ... you can wear and take with you
- ... makes you get noticed by the traffic
- ... is more or less water proof
- ... makes you considered being cool by others (if you can't be cool wearing the gear you make, then what's the point of making it? ^_^)
Stuffing an inner tube with electronics is a bit like putting a ship into a bottle: It can't be done, unless you know the secret. The secret for stuffing an inner tube is to flip it inside out. Then mount the electronics, and then flip the tube back, with electronics and all.
In the six following steps are over 50 pictures of the making of the Flip-flop-inner-tube-bike-light. Comments are added to most of the pictures. Have fun making your own inner tube bike light!
Remove these ads by
Signing UpStep 1Tools and materials
Materials:
For the inner tube led-array:
- Inner tube (of a bike. It's going to be a Bike Light, you know)
- Paper sheet (to take the measure of the bike light's circumference)
- 8 - 10 leds, 5 mm model (I used to cheapest possible leds (€0,05 a piece), just because I had them around. You might want to choose more efficient leds. If you do, take notice of the desired current through the leds: The circuit can deliver a max of 200 mA for ALL the leds!)
- 2 x 70 cm (45") of stranded wire, in different colors
- Silicone gel (to seal the leds in the inner tube)
- A silver marker
- Duct tape (of course!)
For the flip-flop circuit:
- 2 electrolytic capacitators (elco's): 1 x 100 uF, 1 x 22 uF
- 4 Resistors: 2 x 1 kOhm, 2 x 10 kOhm
- 3 Transistors: 2 x BC547, 1 x BC557
- Jumper wire (or just some stranded wire you ripped out of a junkyard PC)
- Circuit board
For the powersupply:
- 1 CR2450 cell battery
- 1 battery clip for the CR2450 model (PCB version! I used a SMD-version, which I had to hack into a PCB version :-s)
- Switch that can be mounted onto a circuit board.
- 6 small Tie-raps (to fix the leads between the circuit boards and the led-array)
For the electronics:
- Soldering iron and solder
- 3.5 mm drill (0.14")
- Cutting Pliers
- Needle nose pliers
- Stripping pliers
- Multimeter (just for checking and/or debugging)
- Third hand
- Small saw or dremel to cut the circuit board
- Water proof sanding paper (roughness 300 or higher)
For preparing the inner tube:
- Punch, 3 to 4 mm (0.12 to 0.16") diameter
- Scissors
- A _metal_ ruler (to punch holes into _one_ side of the tube, not both)
- Pvc tube (1" diam) that is longer than the piece of inner tube you use
- Some cardboard (to mount the led-array when soldering)
- To flip the inner tube inside out: a long, thin, stiff rod with a loop or hole on one end :-D Find a name for that tool: Flipping aid? Flip-rod? I used a cross-brace that comes with ikea's GORM racks. Worked like a charm.)
Wat zijn de verschillen en welke moet ik hebben.
alvast bedankt.
http://www.instructables.com/id/Homemade-Belt-No-sew/
thnks
Anyway, kids can never wear too many light on a bike at nighttime, I guess :-)
To make my bike-light fully-not-officially-legal in NL, you should wear two of them, one red and one white. Both non-flashing. The flip flop circuit should be tweaked to flash at a frequency of about 100 Hz: The leds appear to light up continuously, because our eyes can't keep up with the frequency. So you will still save energy from the battery.
I guess its somethign to do with the rider being higher and could dazzle road users as they are higher up..
"•To flip the inner tube inside out: a long, thin, stiff rod with a loop or hole on one end :-D Find a name for that tool: Flipping aid? Flip-rod? I used a cross-brace that comes with ikea's GORM racks. Worked like a charm.) "
In the US the colloquial term is a "fish" as in a wire fish used to pull electrical wires through a wall or thin electrical metal tubing (EMT). Great improvisation.
Most US jurisdictions have rules on flashing bike lights including read on the rear. Often broken, where I live is very liberal contrary to many other of the laws. Go figure.
Every bicycle ridden between sunset and sunrise must have at least one white headlamp with the light being visible at least 500 feet to the front. The bicycle must have a red reflector on the rear visible at least 600 feet to the rear. On roads posted with speed limit of 35 mph or greater, the bicyclist must additionally be equipped with at least one red taillight visible from 500 feet to the rear. Taillights may be steady or blinking, are allowed under all conditions, and may be attached to the cycle or rider.
Code of Virginia § 46.2-1015.
Thanks for the rules on bike-lights, both in US and UK (Cinderellaman)! I'll look up the precise rules in NL, and try to make a "traffic-rule-proof" version of the bike light. And also use more powerful leds then.
How's Nijntje called in the US / UK? She's a Stargazer on a cloud!
