3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a Bluetooth Mono Headset/Mic on the cheap
  • 4402-0042-Cardo-Wireless-BTA-II-Bluetooth-Motorcycle-Headset-Adapter_sm.jpg
This instructable will show how to make a standard bluetooth headset act as a wireless mono earpiece, using sound from any 1/8" (3.5mm) stereo headphone jack. The microphone can also be used for skype or online gaming for consoles or PC. This instructable may also be useful for those who listen to streaming audio, podcasted radio shows, or listen to audiobooks from their mp3 players. The applications for this are pretty broad, and the price is less than $20.00 if you already own a bluetooth headset.
Step 1External Bluetooth Adapter
Back in the old days (late '90's-early 2000's), not all phones came with Bluetooth built in. This prompted companies such as Cardo to build external bluetooth adapters such as the BTA II. There are others available, but I got one of these for $.99 (used) on eBay. These can be repurposed with a little soldering to send an audio signal to any bluetooth headset, and deliver an audio signal back from the microphone if desired.
First, obtain your BTA II. Got it? Cool. Now use your thumbnail to pop the cover off. You'll see a battery, a circuit board, and the coiled wire that connects to your cell phone. Three wires connect the wire to the circuit board, on mine they were colored white, red and black. The white is +microphone, the red is +speaker, and the black is the common ground. De-solder these wires after carefully noting their orientation.
26 comments
Aug 19, 2010. 9:00 AMphithosd says:
I was wondering if u could use an 1/8" to 1/4" adapter instead of opening it and soldering
Nov 18, 2011. 2:22 PMcsknickerbocker says:
Yes, but the adapter must be stereo to stereo. A mono adapter will not work.
Nov 10, 2010. 4:56 PMdane24 says:
a very good idea but were can I find a external bluetooth adapter?
Jul 10, 2010. 8:55 AMDemascus says:
I found several on ebay and amazon as well, new ones but they are there. Any ideas on how to hack a blue tooth ear piece to blue tooth ear piece. Want to make a wireless intercom from one motorcycle helment to the other.
May 29, 2009. 9:10 PMapplesaucemodifier says:
i just finished this project, it works out quite well, but sound quality i not perfect, i was wondering whether it was the adapter, or the headset? (after all, the headset only cost 5 dollars)
Jun 6, 2010. 2:05 AMLance Mt. says:
Probably headset. I have a headset that sounds almost 8bit, although i'm sure its 24bit sound. Not graet but works for what i need it for. Nothing. Sorry its a bit late
Jun 6, 2010. 2:15 PMapplesaucemodifier says:
Yeah same here, mine worked for bout a year with my ipod til one of the buttons of the adapter got all messed up. Thanks though
Jun 11, 2010. 12:15 AMLance Mt. says:
Always worth a try. Thanks author for your work.
Apr 15, 2010. 10:54 PMDemascus says:
So if I added a small mic to the white wire I would have a wireless mike to a blue tooth ear piece is that correct?
May 3, 2009. 7:01 PMomgthatscool says:
I built this and It worked. The White wire is the Microphone input, so i was able to use the Cardo Bluetooth adapter to go completely wireless. Now I have a completely wireless stereo headset. I also spliced in telephone interface onto the Mic and Audio feeds, now i can use my Bluetooth headset to take calls from my Proprietary phone card, instead of using a corded Plantronics headset. Not bad considering those operator type headsets will usually run you around $200.
Apr 14, 2008. 7:30 PMhacks4life22 says:
where can you buy the bta ii adapter? like in general store not online
Jul 8, 2008. 11:39 PMinnovator1 says:
Can you also use the Jabra a210 Bluetooth adapter? I have two of them, and in taking one apart I noticed it has 4 wires from the connector to the circuit board. Any thoughts on using it? Also, would it be possible to simply plug it into my BT enabled phone with a headset jack and get it to pair to my BT headset for mono sound without modification?
Apr 30, 2008. 7:22 PMjims72 says:
I got mine at RadioShack, but you can go to www.cardowireless.com and they have a "Where to buy" link.
Feb 5, 2008. 10:08 PMicedude007 says:
Thanks for this instructable but my bluetooth have 2 red and 1 green which is which? plz help me
Jan 23, 2008. 6:54 AMAureliano says:
I would like to implement the microphone. Do you think that it will work as good?
Jan 22, 2008. 7:14 PMshrimpcracka says:
would this work for my cell phone? i have an mp3 player on it and its also bluetooth compatible. i would kill for a wireless headset for my phone.
Oct 28, 2007. 11:59 AMHawaii00000 says:
Will this give the ipod touch i mic
Jan 18, 2008. 5:15 AMjongscx says:
...it CAN. but I don't think that the touch has audio-IN jack (per se). If you look around the intarwebs however, there are schematics for the audio IN pins on the bottom jack... Just hook those up to the leads here, and you'd be all set.
Sep 14, 2007. 9:29 AMmindstormmaster1 says:
Thanks that is so cool I will have to get on and try that. How do you pair the bluetooth headset with the dongle. Ethan
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
32
Author:stuffman
