There are few ways, though, as gentle and serene as the warmth of a candle.
Remove these ads by
Signing UpStep 1What you Need.
My Clubbers used foil pie-tins as the hulls of the boats, kitchen foil as the sails and tea-lights to provide the heat.
We have, in the past, had success with normal-sized candles trimmed to only half an inch in height, or small clusters of birthday candles.
Science+imagination=Instructables.
Firstly, Newtonian mechanics (physics) coupled with fluid buoyancy effects (Archimedes) is causing the propultion. Convective heat transfer only causes fluid buoyancy (of the air) which has an action/reaction with the sail.
Secondly, could you consider rather funnelling the hot air into a converging tube that draws air under the boat allows the hot air to push against the water? This should provide a serious increase in propulsion! I have seen such a tube made from a hollow kettle element, but a crimped copper tube should suffice. Any thoughts on such improvements?
i will post my idea soooon, cuz u gave me the best idea ever!!!!! and i have everything that is needed, cause its so simple, YES!!!!!! ha ha, thanks
greatttt instructable!
Drop me a PM when you post it...
Click on a member's name, and you will go to their member space.
On the left, you will see their avatar, with a button beneath, "private message me". Use that to send messages you don't want to be seen by the rest of the site.
http://sci-toys.com/scitoys/scitoys/thermo/thermo.html#boat
you will need to scroll way down the page but is that the general concept?
