Introduction: Make Multicolored Carnations . . . With Science!
Inspired by user NurdRage's video of how to make your flowers glow under UV light, I revisited an old science experiment from middle school. India and I turned a bland spray of white carnations into this lovely bouquet of multicolored flowers, just in time for Valentine's Day.
So come along and join us, as we have fun and learn something interesting about plants in the process!
Step 1: Supplies
This is a very cheap little science experiment, you probably have almost everything you need already around the house:
- 6 vases/cups/jars/etc
- Liquid food coloring
- A highlighter you don't mind destroying
- Scissors
- White carnations--I found a spray of white mini carnations at Albertson's for $3.33
You'll also need to have a black light or some UV LEDs for the highlighter part of the experiment.
Step 2: Prepare the Containers
Fill each of your containers about half full of water. Liquid food coloring usually comes in a package of red, blue, green and yellow, so in the first four jars squeeze out a generous amount of each color--especially yellow, it's usually kind of pale. I bought a package of food coloring just for this purpose, so I used the whole container.
In the fifth jar, remove the ink sponge from the highlighter and dump the whole thing in the jar. NurdRage just used a few drops in his video, but hey, I figure if you're gonna do something like this, why not go whole hog?
The sixth jar is, of course, left untouched as your control. This is science after all!
Step 3: Add the Flowers
Split the carnations into six groups and add them to each container. At this point, cut an inch or two off the bottom of each stem, at a 45 degree angle. Supposedly, it's best to do this underwater, so do it in the jars if you can, or in a mixing bowl, the sink, etc.
Now all that remains is to leave the flowers in their vases overnight (or longer) to let capillary action do its work!
Step 4: Science!
Have you ever wondered how, without a heart to pump liquid around, plants get water from their roots to their leaves and flowers? They exploit certain properties of water to move it against the flow of gravity, through their internal tissue called xylem.
All plants contain a material called xylem which, much like the veins and arteries that move blood around our own bodies, transports water and sap where it's needed in the plant. As water evaporates from the upper parts of the flowers in a process called transpiration, water is sucked up the through the xylem like a straw. Because of the negative pressure at the point of transpiration and a property of water called cohesion (sticking to itself), the water is pulled up to fill the space left by the transpired water.
As this goes on with our experiment over a day or two, the new colorful water is pulled up to the top of the flowers. You can see it in it lacing the flowers, also at the tips of leaves and in the joints of the flowers. The first picture below is the flower placed in the highlighter water fluorescing under UV light. You can really see the fluorescent ink in the petals, as well as the joints of the stems.
Step 5: Final Thoughts
Thanks for joining us on this little trip to Science Land! Praise be to the mighty NurdRage for reminding me about this cool little experiment. It's fun for kids, looks great, and teaches just a bit of the scientific method of inquiry.
If you enjoyed this, don't forget to rate, comment, and subscribe!
As always, if you make your own version of this, post a picture in the comments and I'll send you a digital patch!
