Introduction: Make a Bow Saw (aka Frame, Turning)
Picture of Make a Bow Saw (aka Frame, Turning)
Making a bow saw is easy with a few basic woodworking tools and skills - why not have a go!
Two videos are available. One with full details plus a shot of the plans, the other just showing the build
Free plans are available to download from my website: http://www.womadeod.co.uk/p/blog-page_9.html
You'll need some hardwood - I've used European beech (fagus sylvatica) and Dark Red Meranti (shorea spp.),
some non-elastic cord, a couple of steel pins, and a band saw blade (good way to use up broken ones).
Step 1: Arm Mortises
Picture of Arm Mortises
Layout the mortises as per the plans you downloaded ( http://www.womadeod.co.uk/p/blog-page_9.html ), or to your own design
Chop them out - I've made them through mortises, which I feel maximises the frame rigidity
Tip:
Doing this before shaping the arms makes it easier to clamp whilst chopping!
Step 2: Stretcher Tenons
Picture of Stretcher Tenons
Layout the tenons on the ends of the stretcher
Saw the tenon shoulders and cheeks
Fit the tenon thickness to the mortise at each end
Step 3: Mate Mortise & Tenon Joints With a Curve (Optional)
Picture of Mate Mortise & Tenon Joints With a Curve (Optional)
This optional step makes for a strong hinge connection for transferring tension to the blade
Mark identical shallow curves at the shoulders of the tenons, and entrance face of the mortises, using a pair of compasses
Pare the curves with sharp chisels
Saw the tenons to width, making them narrower at the ends so that they can rotate in the joint
Step 4: Shape the Arms and Stretcher
Picture of Shape the Arms and Stretcher
As an absolute minimum, you need to shape a notch near to the top of the arms, to prevent the tension cord from sliding off
You also need to bore the holes through the width of the lower arms. I also cut a slot here, which allows for a sprung grip on the saw's blade handles
Ideally shape a comfortable grip handle too, and why not include a little decoration as well
A coping saw, rasps, and files will handle all the basic shaping
Step 5: Make Blade Handles
Picture of Make Blade Handles
Turn blade handles on a lathe
Alternatively, glue a slim dowel through a thick dowel to make a very simple but functional blade handle
Slit the slim section, to take the blade
Step 6: Attach a Blade
Picture of Attach a Blade
Install the blade handles in the assembled frame, and drill blade attachment holes
Cut a length of blade the width of the frame (internal size)
Mark for, and drill attachment holes in the blade
Install the blade and secure with steel pins
Step 7: Tension the Blade
Picture of Tension the Blade
Tie a loop of cord around the upper arms, sitting in the notches
Twist cord around and insert the tension toggle (simply planed up from a length of hardwood)
Use the toggle to continue twisting the cord until the correct tension is achieved, and allow it to lock against the stretcher
Step 8: Finished!
Picture of Finished!
You're ready to saw!
To protect your tool, why not give it a coat of boiled linseed oil.
Thanks for reading my instructable. If you build a frame saw, using these instructions and plans, please do let me know, and post a photo if you can
Cheers,
Mitch
Lorddrake (author)2017-05-19
very nicely crafted
About This Instructable
1,387views
35favorites
License:
Bio: Happy in wood shavings YouTube: http://www.youtube.com/c/WOmadeOD Patreon: https://www.patreon.com/WOmadeOD
More by WOmadeOD:French Polish - How to Apply & Restore/RepairKawai Tsugite - Amazing Three-way Japanese JointMake a Child's Country Chair
Add instructable to:
