Introduction: Make a Breadboard at Home
Step 1: MATERIALS REQUIRED
- Plastic brackets / coverings of electric insulations for homes......
- Blade Cutter
- candle
- Compass or any sharp object
- Old hard coverings of any notebook
- Dendrite or any hot glue or any glue
- Scissors
- Alumunium Foil or Sheet
Step 2: Resizing the Plastic Bracket Into Required Length
Resizing the Plastic bracket into required length
Gently cut the plastic bracket into reqd length using blade cutter.....After cutting obtain the top and bottom parts.....
Step 3: Prying Up the Holes of Breadboard
Draw up the schematics of holes onto the plastic bracket.........Light up a candle.....Take a compass and heat it up and then insert it into the bracket to create a hole,......like wise pry up the rest of the holes.......
Step 4: Preparing for the Conduction
Take up the old notebook hardbound cover and cut out a piece identical to the plastic bracket....Keep it on the bracket and pry up some holes at the top and at the bottom....
dotted portion represent the holes in the cardboard and yellow portion is the rest of the cardboard....
Cut out thin cardboard slices from the old notebook cover and paste on the yellow portions .......PAste 2-3 layers of cardboard so that it gains a height from the doteed portions.......On the dotted portions paste the alumunium foil or alumunium sheet......It will be.the conduction channel of the breadboard......
Step 5: Finishing Touch....
Insert the cardboard into the plastic bracket.......Yippee the breadboard is made............
If you like it....pls tag it as your favourite...and do not forget to check out my Instructables page chatsbk007.....for more such projects....
Also you can check out my youtube channel, CSoubhikVids............. :)
Epilog Challenge VI
Summer #mikehacks Contest
squeeze more awesome out of summer contest
Home Technology Contest
