The original design was built in order to cut RC wings (even tapered wings - where one side is different then the other side)
Polystyrene (EPS and XPS) will cut using a hot wire - other foams - like polyurethane should only be cut with a blade or saw.
When cutting, be careful !!! - wire will get hot, and some people may be allergic to the EPS fumes - always work in a well ventilated area.
Remove these ads by
Signing UpStep 1Over View
The first prototype was made out of wood, but didn't look "professional" enough, so I decided to go with a more robust design made of steel.
The design can be modified to almost any size. Keep in mind that for longer travel you will need a longer lead screw.
The problem with a long lead screw is that because it its own mass, it will "wobble" in higher speeds.
One way to overcome this problem is to move to a larger diameter lead screw.
Another way is to move to a chain or belt driven design. Belt driven machines are usually 8' and longer but require the use of micro-stepping. An example of a machine larger then 8 foot would be a surfboard foam cutter.
Some surfboards are up to 12 feet in length, the only way to cut these boards would be a belt driven or chain driven mechanism
I will try to cover this topic in the future with a sample machine and pictures...
We started out building a machine to cut wing cores, but soon after we discovered a huge interest in the machine for other industries - like moldings, architectures, surfboards, Logos, props, packaging Willow Sills, Casings, Wainscoat , Fascia, Crown, Parapets, Wallcaps, Pediments, Quatrefoils, Columns
www.8linx.com
About how much did this all cost? I'm really interested in replicating it
Credito Pessoal
An excellent idea is to use an old vacuum cleaner to collect the fumes and exhaust through a wet filter.
I have hot wire cut PU foam but it requires a much higher temperature and a much slower cutting rate. It is extremely corrosive of the cutting wire and produces ugly charred patches. I would not recommend it.
I want to make one like this except it will be 6' long and 3' tall. I have heard if the key screw is to long it will shake at speed. If I use a key screw that is a 2 start or 4 start the screw will turn slower minimizing the 6' key screw shaking, right.
Do people use over 1 start with hot wire foam cutters?
Anything longer you will need to go for a chain or belt design
Thanks
we use them on our machines www.foamlinx.com
i guess to better answer your question, could you - yes, would you be happy with the results - most likely not. Hope that helps
We are in northen CA - www.foamlinx.com
http://www.zcorp.com/Products/3D-Printers/ZPrinter-310-Plus/spage.aspx
