Introduction: Make a Can Tab Bracelet
Picture of Make a Can Tab Bracelet
Got a bunch can tabs laying around? Or just want to make a cool bracelet? Well, I'll tell you how.
Step 1: Step 1
Picture of Step 1
First, get what you need.
I used about two feet of string and 22 can tabs.
You might need more or less, depending on your wrist size. I'm a tween so my wrist is small. Keep in mind the thickest part of your hand, since when it is finished you will be sliding it over that and don't want the bracelet to get stuck. It would be a good idea to have more string than you think you will need and extra can tabs.You want to make it big enough to slide on your wrist, but not to big so it doesn't fall off. You can also color your can tabs with a sharpie or paint them with nail polish. I found that the sharpie rubs off, so try putting clear nail polish over it.
Step 2: Step 2
Picture of Step 2
First, take a can tab and your string. Put the ends of string in the holes of the tab (one end in each). Look at the picture to see how its supposed to go. Pull the ends of the string so they are even.
Step 3: Step 3
Picture of Step 3
Take another can tab and, with the bottom part facing up,take the ends of the string and push them up through the holes.
Now, take the ends and put them through the top can tab's right side holes. It should look like the picture.
Step 4: Step 4
Picture of Step 4
Put a tab next to the top one and put the ends through the holes. Lift the tab up a little bit and put the ends down and into the right half of the bottom tab. Look at the picture to see if you did it right.
Step 5: Step 5
Picture of Step 5
Now put a tab under that and push the ends through it and up into the top right one.
Step 6: Step 6
Picture of Step 6
Keep putting tabs on the top and bottom until it is long enough to fit on your wrist. Check its length by putting it around your wrist. If the two ends touch, add two or four more tabs so it's not too tight. If your string is elastic, you might not have to do this. Have an even amount of tabs on your bracelet because it will be easier to tie that way. If you ran out of string, try to tie some more on or whatever else you can think of. I sewed my ends together.
Step 7: Step 7
Picture of Step 7
Tie the ends together and go show it off. Or, if it doesn't fit good give it too someone else. Mine didn't fit so I gave it to my little sister.
hope the boss (author)2017-09-07
thx very helpful
Runningwater207 (author)2016-01-06
You can use they spray paint in the cans. then apply a gloss finisher. I prefer to use the spray can kind and the gloss finisher makes sure you piece is protected.
BlazeDamon (author)2013-10-11
Thank you, I was doing it the VERY long way
DIYDIVA2 (author)2012-03-30
I would just like for the color to stay as long as possible. My husband is an artist and has many different types of paints. Perhaps I could use his airbrush gun and whatever type of paint that works for aluminum.
jellybeensis (author)DIYDIVA22012-03-30
I would try asking your husband for some advice, he might be able to help. I just suggested nail polish because thats the first thing I thought of.
DIYDIVA2 (author)2012-03-29
So if I want to color them with say blue nail polish, should I apply the clear first or just the blue? This is a great way to recycle.
jellybeensis (author)DIYDIVA22012-03-29
the clear coat first might make it last longer, but you definitely want to apply a clear coat after the blue
Inspirationn (author)2012-02-23
Awesome! Very Funny. (;
scoochmaroo (author)2012-02-20
Very nice, and easy to follow!
jellybeensis (author)scoochmaroo2012-02-20
Thanks!
About This Instructable
24,881views
115favorites
License:
Bio: I realized that I'm kinda weird in a really fantabulous way.
More by jellybeensis:Make a Chunky Flower RingPut Your Hair Up With a Bobby PinDecorate Bobby Pins
Add instructable to:
