Make a Cheap Spot Welder
5,184
69
6
Published
Introduction: Make a Cheap Spot Welder
How to diy a cheap spot welder
Step 1: We Will Remove Secondary Coils With a Hacksaw
Part list:
01. 12V Relay Module External Trigger Delay Switch Time Adjustable
https://www.banggood.com/External-Trigger-Delay-Sw...
02. Button Switch
https://www.banggood.com/3A-250V-Off-on-Non-lockin...
03. 0.15x8mm Nickel Plated Steel Sheet Strap Tape Strip For Battery Spot Welding
https://www.banggood.com/0_15X8X200mm-Nickel-Plate...
Step 2: We Will Add a Second Coil
I use the 70mm cable from old generator you can use other types welding cable. I recommend using a 35mm or more cable
Step 3: Box
I use old ATX psu for the box
Step 4: Timer - Switch - Welding Needle
01. Timer
You try to use other types but there is a note that you should select the timer can set the value is 0.1s. Because if your transformer is of great value long time can burn nickel.
02. Switch
I use a foot pedal from old motor bike. You can use a button as step 1.
03. Welding Needle
I use a needle of electrical soldering iron gun. There are many options for you
Step 5: Modular Design
I designed the module to avoid the wires.
Thanks for watching my friends. See you on next project
You can support me by watching the clip on Youtube.
    • Creative Misuse Contest
    • Clocks Contest
      Clocks Contest
    • Oil Contest
      Oil Contest
    6 Discussions
    DanC317
    Tip 14 days ago
    Instead of using another connector for 12V, you could add a power supply inside and connect it to mains.
    Thanks my friend because i can use a 12v adapter for more project
    Yes my friend. You can see on clip 4:55 my finger touch the cos
