Make a Christmas Star
Introduction: Make a Christmas Star
Use the elastic properties of thin wood strips to build this six pointed Christmas star, or 3D cross
You'll need six strips of wood and a few hand tools or a whittling knife
You can see me build mine in the video
There is no limit to the size, but you'll have to juggle wood species, length, width, and thickness of the strips to get them to bend the right amount - the sizes I give should work in common timbers
Please vote for my instructable, if you like it, in theHand Tools Onlycontest
Step 1: Wood Prep.
Rip six, 3mm (shy 1/8") thick, strips of wood from the edge(s) of 25mm (1") thick piece(s), 350mm (14") long
You can use a single board, but I used three different species (pine, walnut, and light red meranti) which gave a nice contrast
Gang all the pieces up and plane the edges to get equal widths
The vertical pair should remain at 350mm, but the other two are reduced to approximately 250mm (10") to make the horizontal arms
Plane the faces smooth, while reducing the thickness until each strip can easily be bent to give a deflection in it's length equal to it's width (approximately 25mm / 1")
Step 2: Marking Out
Mark a point and a hole at one end, and a tail at the other
The hole will need to be large enough the easily accept the tail, inserted at a shallow angle
Step 3: Cut Out
Cut out the points and tails, and drill the holes
I used a fret saw and hand drill, but a decent knife could alternatively be used
Ease all the edges, especially the tail, with a file or sandpaper
Step 4: Assemble
Once you have your six pieces, you can assemble the star
For each pair, match a pointed end with a tail. Insert the tail into the hole, and carefully bend the other two ends towards each other, inserting the other tail in to the other end
Make the two arms first, then insert one through the other
Now comes the tricky bit. Assemble the vertical pair through the crossed arms
You're done! Hang it up with a piece of black cotton or thin fishing line and have a great Christmas (or alternative celebration ;-) )
Please vote for my instructable, if you like it, in the Hand Tools Only contest
Thanks for reading my instructable /Mitch
    • Paper Contest 2018
      Paper Contest 2018
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
    Oh, that's such a great idea! Nice and easy but looks really pretty :)
