3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a Cloud Chamber using Peltier Coolers
Cloud chambers let you see vapor trails left by radioactive particles!
A version of this cloud chamber is now available for purchase (fully assembled and tested) from http://www.nothinglabs.com
Discuss cloud chamber assembly and radioactive samples at http://forum.nothinglabs.com
Cloud chambers work by creating a supersaturation of alcohol vapor.  Vapor trails are then formed when the radiation ionizes the alcohol.
Cloud chambers need to be very cold (about -15f) - so most designs require dry ice.
This design uses inexpensive electrical "Peltier" coolers instead!  No need to buy / store dry ice!
It's fairly easy to construct - and should only cost about $100.
This chamber design cools down very quickly - you can see vapor trails within a few minutes.
On the downside - it's not as cold as a dry ice chamber - so the supersaturated area isn't as thick.
Step 1Stuff You'll Need (Part 1)
Stuff You\
Peltier Coolers (need 2)
- Model 12709 (138 watts "max") for "top" cooler ($8 on ebay)
- Model 12710 (168 watts "max") for "bottom" cooler (also $8 on ebay)
- Search eBay -descriptions- to find specific models
- Often listed as "TEC", "Thermoelectric" or "Peltier" coolers and have TEC1 or CP1 as a prefix to the model number
- Other models with similar wattage ratings can likely be used (bottom cooler should have a slightly higher wattage rating than the bottom)
- Coolers look identical - put a piece of tape on a wire of the 12710 so you can identify it later
- Larger coolers are not necessarily better
- Fragile wires tend to break - avoid bending (might want to buy a spare or two)
- Do -NOT- connect a peltier to power backwards or without a heatsink!
Power Supply #1
- 12v and at least 8 amps (good results between about 11v and 15v)
- Used to power 'bottom' peltier cooler
- www.allelectronics.com part # PS-1512 is a good option for $25
Power Supply #2
- 5 volts and at least 2.5 amps (good results between about 4v and 8v)
- Used to power 'top' peltier cooler
- D-Link JTA0302C power supply on ebay for about $10
- Alternative: Use a PC ATX power supply for both 12v and 5v sources (Google for more info)
CPU Cooler / Fan
- Look for "heat pipes" and a 120mm fan
- Design that can be run "upside down" with good airflow
- The Cooler Master Hyper 212 works well and is cheap (under $30 on ebay)
- Cooler Master V8 works well and looks cool (about $50)
- The Corsair H50 (liquid cooling) works a little better - but is more expensive / complicated (about $70)
- See http://www.frostytech.com/ for other possible coolers
Alternative Single Peltier / Single Power Supply Configuration
- This project can also be built using a single dual-stage peltier cooler
- The 19012-5L31-06CQQ from Custom Thermoelectric ($53) has been tested and works well (order with Moisture Sealing option)
- Requires a 12V power supply capable of 6 amps (5V power supply is not needed)
- Other project details stay the same
147 comments
1-40 of 147next »
Nov 8, 2011. 12:51 PMRadpro says:
I apoligize for the continued questions, I have not recieved my parts yet so it may be easier to understand when I get them. Does the cord, the one similar to a computer cord, all you need? How does this power both units with only one output. Im assuming the peltier and the coolermaster hook together and the cord plugs into the coolermaster. I also see a box in the regulare instructable(the picture between the cord and the peltier) Is this part eliminated due to the single stage peltier. I am sure I could figure all this out when I receive the parts, but I need to make sure I have all the parts ordered. Thanks again
Nov 7, 2011. 9:05 AMRadpro says:
I ordered the single stage peltier and was wondering what type of power supply you used, one that powers both the fan and the single cooler and also looks clean. Where can I get one? Thanks again for your help
Nov 4, 2011. 6:44 PMRadpro says:
Hi, I am a current student pursuing a degree in radiation protection. I have been very facinated with the cloud chamber and have decided to build one for my project at school. I love the one that you have for sale but cannot afford it at the current time. The project that I am building it for is actually for my autocad class, not my radiation protection class. Today I went to speak with one of my potential employers, as they were showing me around the lab I ask them if they had ever seen a cloud chamber. I was stunned that they had not heard of one(being that they study and test sources for a liveing) and they asked if I would bring it down to display when I get done. I was wondering if I could get your advice and maybe a materials for constructing one like the one for sale since I will be displaying it in a proffesional setting. If you would be so kind to help me out with this, and as a thank you I could send you a file of a complete blueprint of the construction and assembly to include with your instruction manuel, and display nothing labs-with your name or names of the people who developed this design when I display the chamber. Thank you so much for your time, and I understand and will hold no hard feelings if you feel uncomfortable sharing your design. I will in no way attemp to sell this or any thing similar. My email is Jessm_6709@hotmail.com. Thanks again, and thanks to all who have sharred their time and information on this site.
Nov 6, 2011. 1:13 AMRadpro says:
I really appreciate your input and help. I am ordering the parts this weekend and will let you know how it goes. As for the blueprints I will b required to show many views, Isometric included and it will be created in autocad. There will be realistic views, assembly views, and schematic view. If there is anything in particular you would like for me to add I would be glad to do so, any view or any assembly methods or dissassembly.Once I get the parts configured manipulating them to show different things is easy. It will be complete around nov.5 and ill shoot you a copy. Thanks again for you help and wish me luck!
Oct 30, 2010. 6:29 AMsamol says:
Hi nothinglabs,
Are the cooling heatpipes efficient even though they are mounted upside-down ?
I mean, there's still the capillarity effect, but the gravity is in the wrong way.
I'm planning to build a cloud chamber but I'm not yet sure if I use your type of cooler or if I need to bend the heat pipe (a single sided headpipe version) in order to make them horizontal.
Thanks for the great tutorial !
Samuel from France
Nov 5, 2010. 1:34 AMsamol says:
Thanks for the help,
I'll use the Cooler Master hyper 212+ since the kingwin is not easily available in France.
My conctruction (almost done, only need the 4 peltier) is inspired by this cloud chamber :
http://wilsoncloud.wordpress.com/2010/05/14/222/
I'll make a little overview when it's working.
Samuel
Nov 11, 2010. 8:16 AMsamol says:
Your actual setup is very neat and gives excellent results ! I almost completed my chamber :
http://samuel.fonteneau.free.fr/cloud%20chamber/image%2013.JPG http://samuel.fonteneau.free.fr/cloud%20chamber/image%2014.JPG
Let's hope it's succesfull !
Edit : It works !!!
Here's a little video of the first experiment :
http://vimeo.com/16731396
still need a little bit of tweaking (the artic ceramic is not well applyed on one element) but it's very promising !
Thanks again for your great tutorial
Samuel
Nov 13, 2010. 12:54 AMsamol says:
Thanks nothinglabs!
I spent last day trying to tweak the machine in order to visualize alpha rays.
In the end, I discovered that the americium button was on the wrong side :D !
It don't even seems to need a HV or electrostatic source.
Sep 22, 2011. 8:27 PMcreatrope says:
Is there anything special about those cpu coolers or will a $1 special from a computer surplus store (a cpu cooler with a fan) do the trick?
The inexpensive ones don't have the heat pipe or large fan - are they important or are you just looking for something with the proper orientation?
Sep 3, 2011. 10:11 PMcreatrope says:
The 12710 on ebay all appear to be 106w, not 168w. Is this model number correct or is there more than one 12710? http://bit.ly/pOSwgB
is there an alternative source or model number?
thanks - creatrope
Sep 11, 2010. 3:50 PMKenRocks says:
First off, thanks so much for the awesome build. I've been messing around on the net for a day or so trying to find a non-dry ice cloud chamber and yours is the first set up I've found that anyone can confirm function of...
One thing I'm curious about is generating the vapor for the chamber. Most folk seem to do it the same way as you: soaking a sponge/cloth/etc with solvent and attaching it to the top of the chamber. I was wondering if you had ever experimented with actually warming the solvent in another container and piping it over.
My goal with this would be to make a chamber I could run more or less indefinitely...anyone ever tried this?
Jul 23, 2010. 4:05 AMUgifer says:
Surely the plan would be to connect the power for a second or two at a time until you can detect whether the top is getting hot or cold. That way it never need go about about 40C and there's no scramble to disconnect it if it's getting hot. Great project BTW.
Jun 1, 2010. 6:59 PMDjFluorescent says:
 I was totally waiting for a KABOOOOOOOM! *mushroom cloud*
May 23, 2010. 9:04 AMjoseph.raul1 says:
Been having fun with the chamber for a few weeks now.  Have tried a variety of sources, including exposure to a dentist's x-ray machine:
http://www.youtube.com/user/josephraul1
Great little unit.  I have made a few changes, but overall the basic unit here will work fine.
May 8, 2010. 10:58 AMneimad says:
 So far I have not read anywhere a mention of what type of alcohol to use. I'm sure this is probably an important detail. Some people may not know exactly what to use.  Can you please include what type of alcohol to use for best results?
May 10, 2010. 9:08 PMjoseph.raul1 says:
One other thing you can try is to "salt out" standard isopropyl alcohol to get 99% purity:
http://www.instructables.com/id/How-to-Salt-Out/
I did this today and it works as the alcohol separates to the top while the salt stays on the bottom.  Only drawback is that the resulting alcohol may contain traces of salt.
May 9, 2010. 9:03 AMjoseph.raul1 says:
(removed by author or community request)
May 3, 2010. 5:14 AMsimplyscience says:
May 4, 2010. 1:09 PMsimplyscience says:
May 6, 2010. 5:48 PMsimplyscience says:
May 5, 2010. 6:25 AMsimplyscience says:
May 1, 2010. 3:43 AMjoniverson says:
I built this device also a few weeks back.  I found that, although the fan cooling does a good job, you get slightly better performance (thicker, fuller trails) if the heatsink is immersed in ice water with the water being circulated by a fountain pump.  I know this takes away portability, but it's worth the extra effort if you plan on using it long term because the tracks also stick around longer.  Not as dependent on charge either (I found the extra cooling really helped with alpha sources without much additional charge).
One other thing you can do which helps somewhat, although not as much as ice water immersion, is to place a "blue ice" pack in front of the fan (just don't allow the pack to reduce fan circulation too much or you'll burn out the fan).  This also cools the chamber more, but obviously not for long term.  In a pinch however, it is as effective as ice water for a short period of time.
Good luck to all who try it.  As mentioned, with the project in its current form, proper charge is the key to keeping everything working smoothly.
Jon I
Apr 30, 2010. 7:25 AMjoseph.raul1 says:
My latest, best results using fairly strong uraninite:
http://www.youtube.com/watch?v=sQcUoLQ2hd8
Joe
1-40 of 147next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
51
Author:nothinglabs(Nothing Labs)
Hi, I'm Rich Olson (nothinglabs.com). I sell cloud chambers for viewing radiation, make robots and dev software. I like Instructables with complete info on doing cool stuff with cheap / common parts.
