3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a DOS Command
Make a DOS Command
Many people think that DOS is outdated, but I don't think so. You can do many things with DOS,and even Eric Wilhelm uses it! (See here) Some of the things you can do with DOS include giving yourself access to important files (good for hacking), deleting things, backing up things, showing all the files and folders in a folder, making simple but harmful viruses, and reformatting hard drives (!!). Unfortunately, when you want to run a program you made, you must type in the location if you want other information to be passed on to it. This instructable will teach you how to essentially make a command so you don't have to do this.
Step 1Making the Program
Start by making a DOS executable. A DOS executable is a program that is run through CMD. These files can have six extensions: .exe, .com, .bat or .cmd .vbs or .vbe. Note that that you can use things passed into the program with %1, %2, %3 and so on.
When you have the program ready, rename it to the command you want, followed by its extension. Note that the command cannot contain spaces.
When ready, continue to step two.
42 comments
1-40 of 42next »
Nov 5, 2009. 2:14 PMmicrochip55 says:
you have to have admin permissions to though! is there a way without being a admin or making you on in cmd?
Jan 12, 2010. 9:00 PMchriskarr says:
Another method of accessing System32 is using Linux on an external drive and connecting it to the Windows box. You have full access to all of the system's files and the system administrator can do nothing about it! My friend, Tyler, does this and deletes system32 or renames it to profane names or things which are memes.
Jan 16, 2010. 8:12 AMmicrochip55 says:
but HOW would you do that?
Jan 17, 2010. 10:25 AMchriskarr says:
You would go about doing this by installing a linux partition on a USB hard disk, inserting the hard disk and, when the "select bootable hard disk' message appears, choose your removable disk. The computer will boot off of your disk and the entire hard disk of the system will be easily manipulated without restriction.
Linux is an interesting OS. When you're using it on a harddrive also containing Windows, it says, "You know what? Go ahead and f*** this OS up; it's not me, so I don't care."
When you try to access files in a Linux partition from a Windows partition or a different Linux partition, the one which you're trying to access says, "What do you think you're doing? These are mine, and I won't let you see them, a$$h***!"
When you try to access the system files in a Linux OS which you own, it says, "Ummm...You need Root-Access to view these. Wait, what do you say? You have Root-Access? Well, I don't give a d***. If you want me dead, you'll have to do it my way."
Doing anything to or from Windows OS', Windows says, "Can I help you with this? Perhaps I can bend over a little further."
/me is visualizing the paperclip in Microsoft Office bending over past its elastic limit.
Jan 9, 2010. 7:53 AMgryffn says:
 i got to system 32 with run.exe
Jan 15, 2009. 6:22 AMraaams says:
byyyyyyyyyyyyyyyyyyyyyyyyyyt
Jul 20, 2008. 8:44 PMranumm says:
powershell...
Jul 22, 2008. 5:14 AMranumm says:
PowerShell is a new Command shell replacement for Windows. Object driven, and expandable using .NET Quite frankly it rocks. (let the windows bashing begin...)
Dec 20, 2008. 8:21 AMiRule says:
vb is very good to .. it uses .NET if your using the program thing
Dec 20, 2008. 12:36 PMiRule says:
cool .. lol its very good.
Dec 20, 2008. 2:17 PMranumm says:
VB is ok, but if your serious about .NET, consider C#. Functionally, there is little that C# can do that VB cannot, but...C# is slightly more powerful, and much more consistent. Also, very much in demand right now...
Dec 20, 2008. 2:24 PMiRule says:
i have the thing with vb, C,C++,dll, and all the others built into that program thing that makes it easier to write em.
Dec 20, 2008. 3:19 PMiRule says:
im no good at c++ so i dont try lol
Dec 20, 2008. 1:53 PMiRule says:
while we off subject have you got any ideas for a batch or vbs or vb.net thing .. i ran out of ideas
Dec 20, 2008. 1:48 PMiRule says:
lol yer .. lol .. gone way off subject
Jun 6, 2008. 11:50 AMAndyGadget says:
My first IBM compatible computer was an XT, with, if I recall correctly, a 4MHz clock speed and 256KB of RAM (that's Kilobyte, not Megabyte). CPUs are now pushing 4GHz - That's a thousand times faster (and much more efficient). I've absorbed new knowledge over the years as each new generation of processors and software came along, and really don't envy anyone trying to get into the technical side of computing from scratch now. There is just SO MUCH to learn - including neat little tricks like this. It may have been the ONLY operating system on the early machines, but DOS still has much to offer. *3 yorkshiremen mode ON* You've got it easy today. When I was a lad we didn't have ones and zeroes. We had to make do with 'I's and 'O's. And even the 'I's were a bit iffy. Kids today . . . don't know they're born. *3 yorkshiremen mode OFF*
Jun 6, 2008. 12:00 PMAndyGadget says:
Jun 5, 2008. 7:52 PMGorillazMiko says:
What's a DOS command? Sure, I am stupid for viewing the Instructable and not knowing what it was, that's why I asked.
Jun 7, 2008. 4:10 PMBrennn10 says:
You can make it be matrix colored like in my instructable!
Jun 6, 2008. 8:33 AMPKM says:
I was all set for this to be more lame script kiddie stuff.. and then it turns out to be something hella useful I didn't know you could do. Shows how much I know :)
Jun 5, 2008. 1:19 PMMr. Rig It says:
Who the heck is Eric Wilhelm?!?!?!? J/K :-)
Jun 5, 2008. 11:33 PMMr. Rig It says:
LOL
Jun 5, 2008. 5:48 PMkillerjackalope says:
Rig it was joking, nice one on this, I have dabbled in DOS but could never be bothered with the whole repeating things over an over typing crap out the long way...
1-40 of 42next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:puffyfluff(3,000 Farad)
I live in Estes Park, Colorado. I like anything to do with science and I do a lot of sciency things.
