Make a Distance Meter
1,199
14
Posted in TechnologyArduino
Introduction: Make a Distance Meter
About: Make your own things........
In this instructable, I have shown How to make Distance meter with Ultrasonic Sensor and Arduino nano.
Step 1: How to Make Distance Meter
Step 2: Material Required
1. Plastic Box
2. Arduino Nano
3. Ultrasonic Sensor (HC-SR04)
4. Servo Motor
5. Vero Board
6. Battery
7. Switch
8. Header Pins
9. Wire
Step 3: Make the Circuit Board
Make the circuit board as per this circuit diagram.
Step 4: Arduino Code
Download the code from the link
#define echoPin 6
#define trigPin 7
#include Servo myservo;
void setup()
Serial.begin(9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
myservo.attach(9);
myservo.write(180);
void loop()
float distance, duration;
digitalWrite(trigPin , HIGH);
delayMicroseconds(100);
digitalWrite(trigPin, LOW);
duration = pulseIn(echoPin, HIGH);
distance= (((duration/2)/29.1/100)*39.37);
int angle = map( distance, 0,12,180,0);
myservo.write(angle);
/*Serial.print("Distance is"); /////////////////////////////////////////////////////
Serial.print(distance); //////Use this section to check///////
Serial.println("in"); //////every thing is ok//////////////////////
Serial.flush(); ///////////////////////////////////////////////////////
delay(1000);*/
Step 5: Cut the Edge of Plastic Box
Cut all the extra edges of your plastic box.
Step 6: Make Some Hole
Make some hole as per your circuit board dimension for your switch, charging port and also for ultrasonic sensor.
And also make some hole on the circuit board for fixing the board with plastic box.
Step 7: Download the Scale
Download this image for scaling.
Step 8: Make a Arrow and Fix Servo
Make an arrow with the cardboard. And fix the servo with glue on the plastic box's front case.
Step 9: Assemble
Step 10: Like and Subscribe
If you like this instructable.
Please like it and also subscribe my youtube
www.youtube.com/c/yobots
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    • Science of Cooking
      Science of Cooking
