Introduction: Make a Drawstring Backpack From a Pillowcase
About: I enjoy making random things off instructables and making my own things. I play the violin and have played for 9 years. I occasionally bake and cook, but I'm usually reading or listening to music.
These drawstring bags are easy to make and are very useful for school.
Step 1: What You Will Need
Pillowcase
Rope
Scissors
If you want to make your bag smaller than the pillowcase you will need:
A Sewing Needle
Embroidery floss
Step 2: Making the Bag Smaller
If you would like to make your drawstring backpack shorter than the pillowcase follow these steps. If you do not, then skip this step and go on to step 3.
At the closed end of your pillowcase cut how short you want your bag to be. Turn the pillowcase inside out and sew a running stitch through the two layers of the area pillowcase you cut. The stitch should be from one side to the other. Turn the pillowcase right-side out and your stitches will not appear.
Step 3: Cutting the Slits
Cut 1-inch slits 1/2 inch from each of the top four corners on the first layer of the pillowcase. (Front right, front left, back right, back left). If you cut slits through both layers of the pillowcase, your drawstring bag will not turn out right.
Step 4: Adding the Hole
Cut a small circle (or circle like) hole through both layers of the bottom two corners. The hole should be about 1/2 inch in diameter.
Step 5: Threading the Rope Through
Take the rope and thread it through the front left slit. Once the rope is through the front slit on the right, thread it through the slit closest to it on the back of the pillowcase. Thread that rope through the last slit on the back and pull the rope, so you have 2 feet of rope. Cut the rope that was not threaded (all the extra that is probably on the floor) to match the amount of rope you pulled from the slits. Repeat  for the front right slit.
See pictures for more clarification.
Step 6: Tying the Knot
Put one rope through the hole. Take the other rope and bring it next to the rope in the hole. Tie a granny know with them and make sure it's big enough to not go through the hole. Repeat on the other side.
Back to School Contest
