3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a Fog Chiller for $10
Fog machines are great for Halloween... but fog tends to rise up into the air, spread out, and disappear. If you do not have a very powerful fog machine, this can ruin the whole effect.
The solution to this is to build a fog chiller. The fog chiller cools the hot fog from the machine, causing it to stay low and billow along the ground.
This is a small fog chiller, which works well and is cheap. It takes an hour or two to build.
Step 1Design and Theory
Design and Theory
About Fog
The principles behind a fog chiller are the ideal gas laws. The warmer air is, the less dense it is, and therefore is pushed upwards by sinking cold air. Simply put, warm air rises, cool air sinks.
Fog machines work by pumping fog liquid onto a very hot "heat exchanger", which flash-vaporizes the liquid. This expansion pushes it out of the nozzle. The fog exiting the machine is very hot, and will rise up.
This device cools the air in which the fog is suspended, therefore causing it to sink to the ground.
Design
I designed this chiller myself, and I think the design is unique.
Fog enters the device at the top. At the top, there is a large expansion chamber, so that the fog can properly mix with the air.
Below this expansion area, there is ice. This cools the fog. Once the fog is cool, it will sink down below the ice into another chamber.
On one end of this chamber, there is a fan to blow the fog. On the other end, there is a hole for the fog to exit. This further mixes the fog with the air, and blows it out.
The theory is that the fog will expand in the first chamber, as well as cool. Once the hot fog has cooled enough to sink below normal air, it drops below the ice and is blown out.
If the amount of incoming fog is too fast for the cooling, then the fog will not cool as much, but will still be forced through the layer of ice, most likely resulting in enough cooling to retain the effect.
The whole device is fairly small, only about twice the size of a fog machine, and can be built with easily obtainable materials for not much money.
45 comments
1-40 of 45next »
Feb 25, 2012. 11:22 PMtinker234 says:
wow awsome if and any way you could change the color of the fog als could i use dry ice for a longer time running than normal ice
Oct 18, 2010. 7:24 PMlockpick says:
You could use this to make a fog screen display. I am currently working on one. Great bile'
Oct 29, 2009. 1:27 PMbrandon83 says:
just finished making this but my new 9V battery gets weak after a few minutes. is there another battery i can use with better results? my fan is 12V, it says.
do i need a few batteries in series?
thanks
Oct 16, 2010. 9:02 PMmman1506 says:
use AA batteries, D or C these batteries will last much longer as the have many more milliamp hours (MAh) than a 9v
Sep 27, 2010. 12:18 PMkef4444 says:
where did ya ghet your smoke machine from?
Oct 14, 2009. 10:22 PMsirlol says:
I'm not sure if I put enough ice in, but I realized room temperatureaffects it a LOT. Essentially, the cold fog will sing through warm air,so keeping the room warm will do it.
I'll try more ice and a low circulating fan.
Sep 19, 2009. 4:16 PMjakeryan9 says:
v Me too! I have the same one. Only that it cost 40 bucks, but I got it for 20.
May 3, 2009. 9:15 PMXOIIO says:
I have the exact same machine! I am so going to make this. im just wondering, could you have the fan where the fog exits, or will it dissapate too much?
Feb 16, 2009. 12:02 AMDJ_JS9 says:
well i am a dj and i have a 200$ DMX and all that industrial party strenth fogger and i was wondering if this would work for that too mine shoots about 20 feet and it about 3 times bigger than his
Jan 25, 2009. 2:00 PMchi chi chippy says:
hey all u out there i was wondering if there is a way to make a fog machine. not a chiller but the machine. if u can help tell me
Sep 7, 2008. 4:45 AMneardood says:
I wouldnt use a 9v battery with a 12v fan. You'l wear out the battery real quick and the fanwill under-perform. Try useing a proper 12V supply or battery
Sep 7, 2008. 5:51 AMfrollard says:
I wouldnt worry about under-voltage on a cpu fan that much; they are pretty tolerant, and simply (as you say) lose speed. If you underpower it too much, it will just stop. I built the other one - super cheap version, and I love the results. I imagine this has a very similar effect, but a constant flow - the fanless one 'billows' more.
Sep 11, 2008. 1:57 AMneardood says:
you're battery is gonna die in about half aan hour if you left it on
Nov 3, 2008. 1:02 AMmunchman says:
You could replace the 9v with a variable power supply
Sep 7, 2008. 4:52 AMneardood says:
good idea though, i'd make one of them if I had a fog machine
Nov 2, 2008. 2:13 PMwupme says:
I really this idea. I think i'm gonna cool it with a PC watercooling system. Just that i'm gonna use the radiator to cool the air. Then for CPU cooler i'm gonna add a thermoelectric cooler to it, with an "aircooler" for CPUs on the other side. I think that could get cold enough. Well if not, i still can use it to chill a PC :)
Oct 31, 2008. 1:52 PMdavidprosser says:
I like this, but the problem is that this unit would be in the wings of my stage, and with the lighting and actors, it gets very warm in this area. So blowing warm air into a box of ice is not the best thing for me. Would it be possible to have the fan fixed internaly and blowing out through a hole? Then no unnecesary warm air would melt the ice.
Nov 1, 2008. 1:45 PMdavidprosser says:
or could i put a piece of plastic or something like a hood on the fan, and have a small hole below the smoke outlet for water drainage
Nov 1, 2008. 11:10 AMgilbert2048 says:
if you have a drainage hole you wont have to worry about the water.
Oct 31, 2008. 3:46 PMFather Christmas says:
well, i had the same fog machine as you do. i also have one from the same company, with an ice chamber built in, made specifically for ground level fog. i like your way though, much more creative.
Oct 31, 2008. 4:23 PMMasterMediaXD says:
Make this and attach it to your fog machine with the ready ice chamber for extra low fog!!!
Nov 2, 2008. 7:54 AMMasterMediaXD says:
It might make frost not smoke! lol
Oct 31, 2008. 5:21 PMFather Christmas says:
hahaha yeah
Nov 2, 2008. 7:55 AMMasterMediaXD says:
maybe snow! lol
Nov 1, 2008. 9:00 PMGooberz says:
I'm reminded of a basic "Swamp cooler" design. Cool, good job.
Oct 31, 2008. 7:05 AMduct tape says:
You should use dry ice in the cooler to give extra fog off.
Oct 21, 2007. 2:38 PMlordhazzard says:
i was thinking, instead of ice maye you could use some form of liquid cooling, like a fridge, with cold water being,. say, pumped out of bucket (with a electric pump) with water and ice, and into the chiller with all the pipes arranged for lots of surface area, then you could refill the water quickly. but i worried about the noise, im a filmmaker and i need a quiet mist/fog machine
Oct 22, 2007. 12:06 PMN!$# says:
This is how the commercial fog chillers work. If you're going for silence, look into using a liquid cooling system for a PC. They will be quieter than a large cooling unit. I can't say how effective the liquid cooling unit may be since it is intended for cooling by conduction instead of convection.
Oct 31, 2008. 4:19 PMjhdesynz says:
Liquid cooling was an excellent thought, but doesn't chill, just cools to room temperature. For the fog to stay low, it has to be below air temp.
Oct 31, 2008. 4:17 PMjhdesynz says:
Hey guys, I work in the theatrical industry and have a few praises and a few suggestions. Excellent job breaking it down. this is basically how a pro-grade unit works. -Dry Ice (frozen CO2) is a must to get a good heavy fog. Its cheap and as long as you wear safety gear, easy to work with. Plus you won't have any water to worry about. You can buy it at some grocery stores, an oxygen supplier or some party stores will have it. -If you run a drier hose between the fogger and the chiller, you won't have to worry about the height. - If you are using dry ice, it will be more effective if you build an interior compartment with a 3in pipe (drain spout pipe with all the holes works best) and lower it to the bottom of the chiller. Then place the fan at the exit instead of the entrance. The fogger's "blast" will push the fog into the chiller fine and the fan will pull the chilled fog out nicely. This will only work with dry ice though as the water will short out the fan otherwise. One other thing, if you use the dry ice, put a blanket on top if you don't fill it to the lid. that will keep as much oxygen away from the dry ice as possible and it won't evaporate as quickly. Good job with a nice, inexpensive chiller!
Apr 4, 2008. 3:39 PMmacwhiz says:
I have the same fogger. i got mine at Michael's and it is so awesome i added a timer controller.
Oct 21, 2007. 6:22 PMadmanrocks says:
ya, I like yours too! Good job!
Oct 21, 2007. 1:42 PMSpectrace says:
thats neat, good instructable. Its nice how everyone takes a different view on the same thing. If i did this, i would have used dry ice instead of ice ice dry ice i think lasts longer, and its alot colder. And one question, where did you get the 13 dollar fog machine, because im looking for a fog machine, not only for halloween. and i only have like 20 bucks for a buget.
1-40 of 45next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:T3Hprogrammer
http://www.awesomelicious.com/about/me.htm
