Step 4Create the screen
2. Use a tape measure to measure the inside of the cooler. If yours is tapered, like mine is, measure it about half way down.
3. Bend the coat hanger into a rectangle matching your cooler's shape, using the dimensions you just measured.
4. Use pliers to wrap the coat hanger around itself to finish it off. Cut off any extra.
5. Gently push the coat hanger rectangle into the cooler. It should be able to slide about halfway. Don't push it in too hard, because you may break the cooler, or not be able to get it out. Once you're sure it will work, take it out.
Add Comment
