3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a Fog Chiller for $10
Step 7Finish up
Finish up
1. Cut a hole above the fan, using the outside of the PVC coupling as a template. The top of the hole should be about 1" (2 cm) from the top of the cooler.
2. Insert the screen you made in step 3-4 into the cooler, pushing it down about half way
3. Push the PVC coupling into the hole. If it's not a good fit, seal it with tape. Make it flush with the inside of the cooler.
4. Poke some holes on the bottom front corners (near the hole with no fan). This will allow the melted ice water to drain.
5. Done! It should look like this.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:T3Hprogrammer
http://www.awesomelicious.com/about/me.htm
