Make a Geodesic Sphere Out of Plastic Straws
CraftArt by
Introduction: Make a Geodesic Sphere Out of Plastic Straws
Whether your looking for fun party or garden decorations, a way to lighten up your living/working spaces or a great way to teach geometry, this instructable will show the way!
Step 1: Gather Parts & Tools
1/32" thick sheet of of plastic (8.5" x 11")
90 plastic drinking straws
Step 2: Cut Hubs & Straws
The attached dxf file can be used to lasercut the (12) five-pointed hubs and (20) six-pointed hubs that are needed to construct a geodesic sphere (aka a triangulated dodecahedron). The hubs should be cut out of 1/32" thick plastic (PETG or equivalent).
You can also print out the pdf version on 8-1/2" x 11 paper to use as a template for cutting them out with scissors or with utility knife on a cutting mat. This is best done by temporarily mounting the paper on your sheet of plastic with a light coat of spray mount, then peeling the paper off along with the plastic sheet's protective layer after the cutting is completed.
Pre-cut hubs are also available on Etsy:
After you've gotten the hubs ready, take 60 of the 90 straws and cut them to 85% of their original length. Set the remaining 30 full length straws aside to use in the next step.
Step 3: Assemble
With the (30) full length straws and the (20) six-pointed hubs, assemble a basic 12 sided dodecahedron.
Each of the 12 sides will be identical pentagons.
Slide straws over every other individual hub spoke to frame pentagons using pictures as a reference.
Make sure to leave 3 alternating spokes free for each of the six-pointed hubs.
See this basic dodecahedron instructable for additional guidance. It uses 3-pointed hubs, which we will be replacex with six-pointed hubs in order to insert additional triangulation for a more spherical surface. The basic dodecahedron framework is the same in both cases.
Now with the (60) 85% length straws and the (12) five-pointed hubs, frame the inner triangulations for each of the 12 pentagon faces of the dodecahedron. See video for guidance on how to slide straws over the five-pointed hubs.
Once you have all 12 ready, begin carefully inserting each of them into the dodecahedron, face by face.
Use the available spokes from the six-pointed hubs to connect the inner triangulations to the outer dodecahedron framework.
The straws can bend but be careful not to crease them. Replace creased straws as necessary.
Step 4: Hang (Optional)
Hang the geodesic sphere as you see fit. Fishing line and a barrel swivel are used in this photo. The sphere can also stand alone. Enjoy!
    • Paper Contest 2018
      Paper Contest 2018
    • Trash to Treasure
      Trash to Treasure
    • Science of Cooking
      Science of Cooking
    no precut hubs found on Etsy
    Hi Herhon, sorry for not keeping the Etsy post current. Please let me know if you would still like precut hubs. thanks!
