3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a Golden Filigree Dragon's Eggcase
Step 4Apply the Filigree
Apply the Filigree
Since I had first considered this expedition and known that at some point I was going to have to fabricate a Golden Filigree Eggcase, I had pondered the creation of the filigree itself, and more importantly how I might hold the egg-shaped cups while applying the filigree in it's hot and liquid state. Tough as I am, even I wish to avoid unnecessary burns to the fingers.
The night before the filigree application, when everything else was ready and I had still no notion as to how this step was going to be successfully accomplished, when by chance it came to me in a flash of inspiration.
It was a beautiful evening and the labour of the day had passed. All about we were settling in for the night and Collinworth had just served me a pre-dinner cocktail dressed with the fruit of the olive tree. As was my habit, idly I chewed on the olive, when as a flash, it came to me... why not use a cocktail stick to hold the egg shaped blighter while applying the filigree. Much to the party's consternation, I had the men unpack the equipment and drill a small hole in the end of one of the cups, just large enough to insert the very same cocktail stick by exerting a little pressure. It provided the perfect purchase on the slippery egg shaped forme.
In fact, I was so excited by the discovery, that I ordered dinner to be delayed while I coated the bound cups in their filigree there and then.
I used a hot glue device of my own invention. The hot glue device is an invaluable tool, which I hope to commercialise upon my return to England. It is of solid construction and is endowed with a central cavity just big enough hold a glowing coal taken directly from the fire. When the coal is placed in the cavity, a small door is closed, securing it in place, and by way of a heat conduction path, a reservoir of animal adhesive particles are heated and by degrees rendered into their liquid state. A leaver exists at the bottom of the device which is employed to pump air into the reservoir, which due to the increasing pressure may expel the liquefied adhesive through a small nozzle, on the pressing of a trigger leaver, thus allowing the user to direct the adhesive as and where required.
The device takes some skill to master, but the effects are useful and pleasing. I am currently working on a device that will be able to melt the glue using electrikal-discharge energy, but I believe that the perfection of that device will take many years.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
333
Author:KaptinScarlet(dadcando)
Eldest of five, son of two doctors, 10 years in Graphic Design and marketing, then retrained as a Biomedical Materials Engineer, don't ask me why, I think it was because I had always wanted to design ...
more »
