Make a Hydroelectric Power Light
2,708
48
Published
Introduction: Make a Hydroelectric Power Light
About: Howdy, we are application engineers in Seeed. Sharing projects with maker community is awesome. Hope you like it XD Seeed is the IoT hardware enabler providing services that empower IoT developers to swiftl...
Recently I received a hydroelectric, use it to make a SAVE WATER remind, just for fun~~
Step 1: The Material Will Be Used
3.6V Micro Hydro Generator Pro*1
Metal Hose *1
JST 2.0 interface *1
Orange bright LED *1
Cable*N
M2 Screws, nuts *4
3M Black tape
Double-sided adhesive
Sealing band
3mm black opaque acrylic
3mm transparent acrylic
Step 2: Laser Cut Acrylic Panels
There are parts of the text for transparent acrylic, other for black Opaque acrylic, and do not cut the text part, please use the scan.
Step 3: Hydro Generators Installation
Hydro generators installation on the pipe before installation remember to sluice off, screw mouth needs winding Sealing band, note inlet and outlet. After installation you can try to open the sluice.
Step 4: Lamp Socket Assembled
According to pictures shown, assembled these parts together, can use double-sided tape to reinforce, hot melt adhesive~
Installed. You can connect the hydroelectric generator to look the effect , and if there is leakage light, you can use 3M black tape to cover his leakage light places.
Step 5: Done
Good luck~
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    • Woodworking Contest
      Woodworking Contest
