Make a Joule Thief
Step 4Try it Out!
Try it Out!
And that's it! You're finished with your Joule Thief. Touch the twisted wires coming from your toroid to the positive side of a battery, and the extension wire to the negative side. If all is working well, the LED will light up! If not, try using thinner wire on your toroid. I've included a schematic in the pictures if you prefer.
26 comments
Oct 19, 2011. 5:05 AMRay Power says:
Thanks for the instructable! I could only get 4 wraps on my CFL salvaged toroide but it seems to work
Dec 26, 2010. 7:21 AMrobot1398 says:
can i use a bc547 transistor in place of 2n3904
Jun 5, 2011. 6:24 AM-max- says:
i used a transistor out of a flash camera, it worked. after playing a lot with it, i found the 2n3904 to be vastly superior. most other transistor didn't work or barely did.
Jun 5, 2011. 7:46 AMrobot1398 says:
i made it with bc547 and works better than 2n3904
Jun 5, 2011. 2:06 PM-max- says:
great for you! i dont know if half the transistors i used were NPN or PNP. i think most were PNP
Jul 20, 2011. 7:58 AMrobot1398 says:
then how did u know the pinouts
Dec 26, 2010. 2:20 PMrobot797 says:
all npn transistors work
when i build one
i get my junk box and desolder the firsth npn i see :P
also if you make the 1K resistor a 2 or 5 K pot you can tune it into the right frequentie
Feb 21, 2011. 3:19 AMrobot1398 says:
thanks
Jul 14, 2011. 4:21 PMRONEDOGG says:
i just tried this for a xbox 360 controller leds. and well it didnt go so well. i used the same size troid same transistor but my resistor was abit different. it was grey in color. and it heats up liek bad. enough where i have a blister on my leg where it fell. lol
any idea what transisotr to use for 4 LEDs?
Jul 17, 2011. 11:00 AMS33PlusPlus says:
Sounds like you either shorted the supply rail to ground or overloaded something (the transistor can only dissipate 100mW or so, and the most abundant resistors are rated for 1/4W)
Which parts got hot? And is there a reason you need to drive the LEDs with a joule theif?
Jul 17, 2011. 11:18 AMRONEDOGG says:
hello. you might be right. i did short out the transistor it started making a high pitch noise after.
it was the resistor that got hot. but i realized that after i forgot the battery on the xbox controller is 2x 1.5v.
i started over again and got it all working.
the reason for the joule thief is with wireless xbox 360 LED ABXY mods, when the battery gets under fully charged the LEDs in the controller dim really fast. and its noticeable after about 30 40 mins of using the controller on a fresh charge.
so i herd talk of people thinking of doing a joule thief in the xbox 360 controller. but no tutorials anywheres i could find. so i pieced this together myself. this joule thief tutorial and another for LEDs in the controller.
how i have it setup now is a 1k resistor from the controller to the joule thief + input. and the - to the joule thief to the - on the controller.
then on the +s and -s on the output of the joule thief i put 4 x 5mm white LEDs.
the batterys in the test controller are completely dead. cant even connect to the console for more then 2-3 mins. yet the LEDs for ABXY are bright.
when im saying + or - im referring to polarity. and my joule thief is using all the parts listed above. just put together abit neater.
Jul 17, 2011. 10:14 AMRONEDOGG says:
yeah lol thanks i was having a slow moment the other day. i figured it out. i forgot to have a resistor coming form the controller to the joule thief. got it all working now.
i just put another 1k resistor off the controller + before the joule thief
battery life at 1 bar and the LEDs are still super bright. now just to fit this troid into the controller housing lol
quick question 1up. if i wrap the troid more then the recommended turns will this improve brightness for 4-6 LED's?
Jul 18, 2011. 10:20 AMRONEDOGG says:
yeah lol im listening. there is one factor your missing. when the battery pack starts to die. the 3.7v is no longer 3.7v its more like 2.0v. so the LEDs dim. i used the right resistor and it did nothing. when the battery's were under fully charged. the ABXY buttons would dim. then by the time the battery got to half, there was no illumination to the ABXY at all.
dunno maybe i am missing something big here. i dont know anything about what im doing but i do know is the joule thief did fix the dim ABXY LEDs lol
If you google around people talk about similar issues with DIY ABXY LED mod on wireless controllers. thats why they mainly do it on wired controllers. because if the battery's for the controller are not fully charged the LEDs are considerably dimmer
I am wiring my LEDs in the controller on the positive and negative leads inside the controller.
Not sure if any of this is making sense to anyone. but i can post pictures and show what im talking about. its clear to see lol
Jul 17, 2011. 11:06 AMS33PlusPlus says:
More turns shouldn't make a huge difference. I made one the other day on the same ferrite core (Dead CFLs are handy!) with ~20 windings of 30AWG magnet wire and I didn't notice improvement over my 12 turn toroid.
Jul 12, 2011. 3:35 AMajain7 says:
Can ferrite out of adapter, which is square in shape, work? I used it with transistor named 13001 and a resistor but it was not working at all.
Jun 8, 2011. 11:15 PMjhao says:
you could get a nice battery holder instead of soldering the wire straight to the tip of the battery :)
Mar 6, 2011. 5:24 AMShemySheza says:
thanks but 1 question-how many wounds of wire?just 10 or can i use more?does it matter?
Jun 5, 2011. 6:21 AM-max- says:
with most Joule Thiefs it doesn't matter. as long its more than 2 or so. the more windings you can fit, the better.
Jun 3, 2011. 6:53 AMjtod says:
How can drawing power OUT of a battery charge it up.? I don't make sense to me.
Jun 5, 2011. 6:17 AM-max- says:
the dead battery still has a lot of juice in it when it wont power up stuff around the house. the Joule Thief will take advantage of that power and charge another battery of course it wont have more charge as the first. as the law of conservation states.
Nov 21, 2010. 6:20 AMrayfalcon says:
hey it works kind of! let me explain whats going on it blinks my led but will not keep it lit up and my battery gets extremely Hot so i quit using the one i just made and taking some time to try and get help on itthe 1 k trans might be wrong on mine its a clear glass thing with Brown black and red on it but its glass and on one side it says 48 thats all it has on it.....Is that a 1k trans or is this a diode? if so can that be the problem?
Charles
Jun 4, 2011. 7:16 PMits2l8men says:
I think it's a zener diode
Jan 7, 2011. 12:39 AMkcarring says:
+maybe it is a 1n4147 diode. resister shouldn't be glass. if it looks like this: http://tinyurl.com/27l63z6 it's a diode
Mar 5, 2011. 10:55 PMlperkins says:
It's perfectly possible to solder to batteries without any ill-effects. Commercial battery packs use spot-welding, and you want the heat characteristics to be as close to that as possible. Basically you want a high-power soldering gun. One of those little pencil irons is not going to cut it. In my experience, a good rule of thumb is to never put your iron to the battery for more than about two seconds, and then let it cool completely first if you have to hit it again. If you can't make it work that fast, you need a hotter iron. I can only speak for Alkaline, NiCd, and NiMh batteries. I wouldn't even try to solder things with "Lithium" anywhere in the name without good safety gear and a fume hood.
Dec 1, 2010. 8:07 PMrhanson294 says:
Not to be offensive, but I have always been told that you never solder to a battery. In some of the pictures it looks like the wire is soldered directly to the battery. Just wondering how safe that is.
Dec 6, 2010. 12:56 PMluiscll says:
I think that with a pair of magnets the soldering can be avoided. Just an idea to who wants to avoid soldering.
Dec 21, 2010. 7:24 AMthomas53 says:
Or just use a battery holder
Dec 4, 2010. 10:29 PMthreewheela says:
its plenty safe as long as you dont overheat the battery because it could explode and everyone knows heat is bad for battery life anyway
Dec 2, 2010. 4:11 AMbeehard44 says:
just do it quickly and never using a button cell
Aug 31, 2010. 4:28 AManupamvipul says:
it would be great if u add theory of coil used and diagram with colour
Jun 17, 2010. 8:33 PMBlofish says:
Outstanding detail!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
261
Author:1up(ModRetro)
Sometimes my Instructables are few and far between, but I try to make them as well as I can. Hopefully you can be inspired or helped by the content in them!
