WARNING: Playing such an instrument may induce Funky-Techno-Madness.
Watch in HD
Watch On Blip.tv
Remove these ads by
Signing UpStep 1Parts and Tools
For this Project you will need...
Parts-
Korg Kaossilator (They are usually yellow but there are limited edition pink ones available too)
RedOctane Guitar Hero Les Paul Controller (It fits perfectly into these models and the removable neck and faceplate make it easy to remove the Kaossilator.)
1 IDC Socket (10pos) for Ribbon Cable (#ci0076)
Ribbon Cable (at least 10 conductors)
.1 Inch Header Pins (Double Row) (#ci0073)
Protoboard
50k Ohm Resistor
1/4" Stereo Output Jack
Les Paul Style Jack Plate
4 #4387 Gibson style pickguard screws
Stereo RCA Audio cable
Great Stuff Expanding Foam Insulation
Tools-
WD40
Hex Screwdrivers
Small Pliers (not needle nose)
Hacksaw Blades (different sized teath cut different plastics better)
Exacto Knife
Vice Grips
3/8" Skew*SHARP! (For cleanup work)
Soldering Iron
Wire Strippers
PanaVise Junior Clamp (#ci0011)
Small Prototype board
Hot Glue Gun
Ok, maybe I'm exaggerating a little. :)
But this is really awesome!
After much research on my part, I have asked my wife to get me a Kaossilator for Christmas this year, because after playing with one at Guitar Center, I must have one. These things are too much fun and addictive. And the only thing that would make them more fun and addictive is having it mounted in a guitar.
Aside from looking awesome, I really think this mod would make the Kaossilator much more playable as an instrument, because accessing the control buttons would be much more ergonomic. Also the sustain button would add a lot of playability to the device as well.
I can't afford to buy one of these, or I would. And right now I can't even afford to parts to build one, but I will start gathering them up little by little, and maybe by then the new will have also worn off of my Kaossilator enough to where I am not so scared of opening it up and working on it. I am an electrician, so I am not scared of the soldering or anything. So hopefully mine will turn out as good as yours did. Painting the guitar yellow definitely added a nice touch.
I can't thank you enough for putting this instructable online, so I can know how to do this myself. I have heard some music made on the Kaossilator and it is very impressive once you know how to use it. And putting it in the guitar frame with the sustain button is only going to add to how awesome it is.
Great job!
Wayne
i saw this instructable and i had to make it, but i too have a limited amount of money, so i amazon-ed it. TGFA
hope you are able to get it now :D
James Haskin
But is there any reason you couldn't put both in parallel, so you could have more options when playing?
Is your parts list on the instructable still good, even after your new improvments?
The parts are the same, however, I no install the resister for the 5th button on the protoboard instead of inside the neck. Also green craft foam from Jo-Ann Fabrics can be used instead of the spray foam. The spray foam is a lot harder to work with.
If not, I could always just plug it into the power supply jack, given I could find the right plug for it somewhere. But I'd rather just use the spare wires on the ribbon cable if there are at least two.
I just think first off it would eliminate the need to cut out that notch for reaching the Kaossilator's on/off switch. And second, if you are planning on leaving the Kaossilator in the guitar most of the time, as I am, it would make changing batteries much easier, because you could just change the guitar's batteries without having to remove the Kaossilator.
The only problem I forsee is that I think the Xbox Les Paul guitar only uses 2 "AA" batteries, and the Kaossilator uses 4. My PS2 wireless guitar controller uses 4 "AA" batteries but it's a totally different shaped guitar, and I don't know how well the Kaossilator would fit in there, plus you have less wires coming from the neck as you mentioned which is not cool either, because I definitely want to use the 5th button as a sustain.
Can you confirm if the Xbox Les Paul uses 4 or 2 "AA" batteries. I really hope it uses 4, but if not, I may try to find a guitar that does.
Thanks!
Yes Currious Inventor has them still.
When you finish post a picture :]
Also, does the ribbon just dangle from your Kaossilator when you're not using it inside the guitar?
Thanks for your help! Will definitely post a photo if we get this to work. We're starting without the sustain feature, not even the guitar jack at first, just want to make it work.
Yeah, when the kaossilator is not in the guitar the ribbon cable just hangs.
It doesn't bother me :] You can make it pretty short but I like to make them 2 feet. You can always go shorter if it becomes an issue.
I'd be happy to skype chat with you and give you some pointers. I have two Kaossilators open at the moment. Just email me insasquatchcountry@yahoo.com
Thanks, great project :D
FYI: Thinkgeek charges far too much for the Kaossilator. Use Kaossilator HQ's link to save starving artists' money :)
I am planing on building this in the summer, I am just a bit confuesd about the sustainer.
Is adding the 50k resistor all I need to do to create the sustainer, or must I also follow 3amsleep's tutorial on sustainer modding?
Please help.
Thanks in advance.
merely a suggestion. AWESOME INSTRUCTABLE!! =D
check out mine, pleaseeee
Thanks
So I'm guessing the buttons are constantly being pressed simultaneously for some reason, since I have to reverse the process of getting into DLY mode.
The XY pad uses 4 leads. I think, I'm just a hobbiest, ones positive, ones negative, and the other two are analog signals out. The 50 ohm resistor is just enough (or just to little) to make it think you're pressing down still.
