Step 7Soldering pt. 1
1.) Desolder existing wires (I cut them so I can pull them out one by one)
2.) Solder ribbon cable to the neck connector
3.) Solder the 10 pin header in the center of your protoboard
4.) Look at the back of the neck connector. There is one wire with a square around it and only it. For instructional purposes this wire is 1. In my picture its the grey one all the way to the left.
5.) Depending on what kind of controller you're using, refer to the corresponding diagrams a solder wires to their correct pins. The "X"s mean nothing is soldered.
6.) Hot glue your protoboard to the body.
comment
Add Comment
Add Comment
