3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a Korg Kaossilator Guitar
Step 8Soldering pt.2
Soldering pt.2
Now its time to open up the Kaossilator. The way I've designed it, this will work in both guitars. 3amsleep and I were working on similar projects at the same time. I found his blog while doing research. On my first prototype I rerouted two connections from each button. Then 3amsleep publish his project on his blog and I saw that you only need one connection from each button and a ground. He's even made a video tut on how to disassemble the kaossilator.
You need to look at these pictures for reference.
http://kaossilator.files.wordpress.com/2009/02/side_b-medium.png
http://kaossilator.files.wordpress.com/2009/02/side_bz1.png
http://kaossilator.files.wordpress.com/2009/02/side_bz2.png
http://kaossilator.files.wordpress.com/2009/02/side_a-medium.png
http://kaossilator.files.wordpress.com/2009/02/side_az.png
Wire it as shown in the diagrams below.
Folding the wire in strategic places keeps everything tidy. You will need to cut a hole in the side of the top portion of your Kaossilator. I used a little drill bit and the skew to clean it up.
When once you've fed the wire out of the hole and closed everything attach the 10 Pin connector by applying A LOT of even pressure. Make sure to line up the triangle on the size of the connector with wire 1.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
66
Author:James Haskin
insasquatchcountry@yahoo.com
